XL125 - VIDEO of it running, popping & banging. Help?
Sachstasy
PostPosted: 16:14 - 09 Jul 2009    Post subject: XL125 - VIDEO of it running, popping & banging. Help? Reply with quote
Hey again guys.
Right, I had the bike running yesterday night and this morning, Went off into the field with it..
Came back today, Got into the garden and.. BANG.
The bike now won't start without it being bump started, Kick starting does nothing but knacker me out.
Before it popped, it did cough and splutter at high-ish revs...
Could this be piston rings? I cleaned the carb out too, everything was in order etc.
VIDEO.
https://i2.photobucket.com/albums/y43/cvh_oncarbs/th_Video0019.jpg
I don't know if your going to be able to hear it properly, but you can definately hear it missing.
I assume it's going to be sparking issues, it's a brand new spark plug so..
Totally baffled. It also whistles when it's revving :S
carlperkins00...
PostPosted: 14:34 - 10 Jul 2009    Post subject: Reply with quote
god that sounds weird!! did the seat fall off?? haha.
on a serious note though... i have no idea. but me posting this reply will bump the topic to the top of the list where someone who can help you will be more likely to see it. Very Happy
haha Laughing
bladerunner
PostPosted: 16:07 - 10 Jul 2009    Post subject: Reply with quote
the sound on that clip is useless as the phone cuts the sound out if it's to loud!!! And that must have been far to loud Laughing
It's an xl125 R which was cdi rather than the xl125 S which was points so it wont be that!
Have you checked the compression? couldnt see any evidence of smoke in the vid though
Also if you unscrew the HT cap and hold it about 8-10mm away from a metal earth point and kick it over will it jump at least an 8mm gap? if so your coil etc are up to the job.
Last things to go looking through are things like valve clearance...if the valve gap is to small it could be holding the valve open a little causing it to miss fire and the such. You have already checked the carb so that I assume is right!
yuri2085
PostPosted: 01:14 - 11 Jul 2009    Post subject: Reply with quote
Why is that lever moving when you rev it?
Paddy Blake
PostPosted: 01:46 - 11 Jul 2009    Post subject: Reply with quote
Did you change the plug cap or HT lead.?
Is it right for the bike and connected right.
ash-2009
PostPosted: 10:19 - 11 Jul 2009    Post subject: Reply with quote
lol i had the same problem with my on-road xr 125 04 model after i took kt off road i got a vid on youtube what it used to do is ths simlar if so mine fixed it self lol after time all i done was treat her to a full tank of petrol with a strong mix of red ex the carb cleaning one watch it tho as i did buy thr rong one at first for car injectors lol :S
Heres The Link .. https://www.youtube.com/watch?v=CopFXv5REt4
sorry if im not ment to do that
Sachstasy
PostPosted: 19:44 - 11 Jul 2009    Post subject: Reply with quote
Thanks for the replies guys.
Right, I've been to the Honda centre by me, and they assure me the plug they gave me was right. I've checked over the cap, and coil, and they both seem to be ok.
I'm going to be scouring Ebay for a replacement coil, if it works after that then it's all good.
I'm not brave enough to take the head apart lol, How do I check the clearances, and compression? It definately feels like there is enough compression through the kick start.
I shall get a better video, I'll get my brother to rev it whilst I video from afar. Very Happy
willi
PostPosted: 22:10 - 11 Jul 2009    Post subject: Reply with quote
you said you cleaned the carb. i say you need to clean it again.take all jets out and inspect them and blow them clean aswell as the jet ports in the carb with compressed air. it sounds like carb issues to me. Thumbs Up
wat goes around comes around.
Sachstasy
PostPosted: 22:41 - 11 Jul 2009    Post subject: Reply with quote
I did all that, I took the carb to a mate who works for a motorbike engine builder and he seems to think the carb is ok.. He only took a quick look though!
I'm thinking of just ebaying stuff, coil, carb, etc and see if changing those things solves it!
Could it have been restricted at all?
Blue_SV650S
PostPosted: 23:27 - 11 Jul 2009    Post subject: Reply with quote
I can't really hear much from the vid.
Have you taken the spark plug out and inspected it?
Have you tried putting the old sparkplug back in?
It is possible to get a duff sparkplug.
Also was it wet round the field? You might want to try WD40 on the HT leads and cap.
Finally, if it is CDI ignition, is the pickup on a plate?? i.e. if it is on a plate, then it may have rotated and hence put the ignition out.
I doubt it is rings BTW as I'd expect it be smoking badly ... it also sounds like it runs fairly slowly, another indication it prolly has compression.
Sachstasy
PostPosted: 23:43 - 11 Jul 2009    Post subject: Reply with quote
I really have no idea about motorbikes, and it seems people I know that KNOW bikes, don't wanna help lol! As said I will get a better video, with better sound etc.
Thanks for all the replies.
Also, does anyone know of any engines that will go straight in? as i'm thinking of binning the 125.. I know they made a 185, and a 200, and 250.. And of course the 600...
The last post was made 17 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 71.22 Kb
