Husqvarna Sm125S Indicator Problem.. Check'd Wires & Bul
ash-2009
PostPosted: 10:11 - 11 Jul 2009    Post subject: Husqvarna Sm125S Indicator Problem.. Check'd Wires & Bul Reply with quote
Cool So anyways i have check'd Wire's For splits or loose connections none found so then i replaced bulbs & Fuses case for some reason something caused them all to pop no joy so now all im left down to is the regulator/recitifier if thats how you spell it could this be my problem if so where could i find one of the pretty cheap maybe ebay or somewhere or could the be something else the bik starts front and rear lights work break light works from rear foot brake and also the front brake man beam works battery doesnt need charging ?? cant think lol help bcf Doc's
ash-2009
PostPosted: 14:55 - 11 Jul 2009    Post subject: Reply with quote
? Crying or Very sad
tutton
PostPosted: 23:44 - 11 Jul 2009    Post subject: Reply with quote
Theres a few more things you need to do before being able to diagnose the issue properly,
First id check theres continuty of the wire from the fuse to the bulb holder, if fuses have been popping, and possibly higher fuses have been wrongly installed, the cables may have fried themselfs inside the insulation enough to make a point of very high resistance in the cable.
ash-2009
PostPosted: 09:51 - 12 Jul 2009    Post subject: Reply with quote
thanks tutton will have a closer inspection after ive had a little to eat Thumbs Up cheers fella.. tutton is always the one to help me out verry helpfull lad cheers again buddy Thumbs Up
tutton
PostPosted: 18:44 - 12 Jul 2009    Post subject: Reply with quote
Another way to try and see if its a wiring or part issue is, run a negative and a positive from the fusebox connection the indicator and light circuit splices into using your own wires, see if you get any life there.
The last post was made 17 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 43.92 Kb
