Aprilia SX 125 power
stuker
PostPosted: 16:02 - 12 Jul 2009    Post subject: Aprilia SX 125 power Reply with quote
How do i check if the power valve on an aprilia sx 125 is working as it should? The bike seems to hit a bit of a flat spot at around 8000rpm.
thanks
PostPosted: 19:44 - 12 Jul 2009    Post subject: Reply with quote
How much of a flat spot? Does it manage to pull properly after 8K?
stuker
PostPosted: 20:45 - 12 Jul 2009    Post subject: Reply with quote
hi. yes it still pulls but it is not as aggressive as between 6k to 7k and 7k to 8k. As it hits 8k the engine note changes slightly (lower) and the power flattens a bit rather than increasing at the same rate as before.
Should there be a significant power incerase after 8 k if the valve is working correctly?
PostPosted: 20:55 - 12 Jul 2009    Post subject: Reply with quote
It should continue to increase. There might be a bit of a "delay" around 8k, but it shouldn't be much of a delay.
Find the solonoid under the tank and check that it moves around 8000rpm (you might want to ride somewhere without anyone around....).
The last post was made 17 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 39.82 Kb
