Chain problem
Bod
PostPosted: 13:00 - 08 Jun 2004    Post subject: Chain problem Reply with quote
Hi all, I have a ZXR 400L with a small chain problem. When the chain is going round, I can hear something slap or rattle as the chain revolves. The chain has been checked and tightened, any ideas?
Bod
Claud 14.7 to 1
PostPosted: 13:02 - 08 Jun 2004    Post subject: Reply with quote
sprockets?
Bod
PostPosted: 13:04 - 08 Jun 2004    Post subject: Reply with quote
the front sprocket does move slightly. Cant really tell if it needs changing? How would you know?
Bod
craigT19
Jolly Green Giant
PostPosted: 17:10 - 08 Jun 2004    Post subject: Reply with quote
Take a look at the teeth, it there worn your notice Thumbs Up
look for this kind of thing...although this example is alittle extreme
https://www.dirttricks.com/worn_sprocket.jpg
and for a little comparison
https://www.constructionequipment.com/prevention/pix/CE03da004h.gif
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
McJamweasel
BCF Junkie
PostPosted: 17:17 - 08 Jun 2004    Post subject: Reply with quote
Thats not extreme. This is extreme!
https://www.bikechatforums.com/download.php?id=2255
craigT19
Jolly Green Giant
PostPosted: 17:21 - 08 Jun 2004    Post subject: Reply with quote
LMAO!!! what happened to that nsr!!! were you too young to buy chain lube or summin Laughing
McJamweasel
BCF Junkie
PostPosted: 17:22 - 08 Jun 2004    Post subject: Reply with quote
Something like that, yeah. Still - it did teach me the joys of chain lube. Very Happy
Bod
PostPosted: 17:44 - 08 Jun 2004    Post subject: Reply with quote
humm, may be a new sproket is in order. Are they expensive?
Bod
McJamweasel
BCF Junkie
PostPosted: 17:51 - 08 Jun 2004    Post subject: Reply with quote
Nope. £20 should sort you out with the pair.
Bod
PostPosted: 17:52 - 08 Jun 2004    Post subject: Reply with quote
are they supposed to be loose? or should they not move at all when you have fitted them?
PostPosted: 19:06 - 08 Jun 2004    Post subject: Reply with quote
There should probably be a small amount of movement in the sprocket.
However check that the chain does not have a tight spot.
mr.z
PostPosted: 19:25 - 08 Jun 2004    Post subject: Reply with quote
you will need to change both your chain and sprockett, otherwise expect whatever you change to wear out quite quickly Sad
as kickstart said check the tension at the tightest spot, too tight a chain is allot worse than too loose and will kill chains and sprocketts very quickly
Bod
PostPosted: 19:35 - 08 Jun 2004    Post subject: Reply with quote
I will double check the tension on the tight spot Sad
Bod
clemsta
PostPosted: 23:38 - 08 Jun 2004    Post subject: Reply with quote
My NS125R's front sprocket has a little movement in it and it's new so i thinks they're designed like that, my back one has no movement. just remember to lube it about every 250 miles if it needs it. you are supposed to change your chain and sprockets at the same time but if the old parts are in good nick i would just save the money. Wink
The last post was made 22 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 79.15 Kb
