| SpicyBlimp |
 SpicyBlimp World Chat Champion
| Vincent |
 Vincent Banned
| SpicyBlimp |
| Clanger |
 Clanger Stirrer
 Posted: 11:32 - 12 Jul 2009 Post subject: |
Mine is plugged in constantly. The alarm unfortunately takes a lot off the battery when it's stood still, so the trickle is the best thing to keep the battery alive.  ____________________ Be who you are and say what you feel, because those who mind don't matter, and those who matter won't mind - Dr. Seuss |
| Blue_SV650S |
 Posted: 12:38 - 12 Jul 2009 Post subject: |
As others have said, optimate is designed to be capable of being left on 24/7!
With 5 months away, you might want to consider some fuel stableizer too though??
e.g. https://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MCYCLE&pcode=PUTFUELSTAB
To be fair, 5 months you can probably get away with, but if you wanna be safe/sure, go for some stabilizer too!  ____________________ The purpose of life is to fight maturity. |
| SpicyBlimp |
 Posted: 02:15 - 13 Jul 2009 Post subject: |
I've brimmed the tank so should get away with it, the bike will be getting wheeled around a bit too to stop anything happening to the tyres, should be alright fuel wise, just need to screw the optimate thingy to the battery tomorrow  |
| iooi |
 iooi Super Spammer
 Posted: 08:56 - 13 Jul 2009 Post subject: |
Unless your bike has a alarm, why bother....
If no alarm, then simply disconnecting the battery will stop any drain, and save the risk of fire, should something fail.
TBH 5 months with it connected should not harm it in any way. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| SpicyBlimp |
| Blue_SV650S |
| iooi |
 iooi Super Spammer
| Blue_SV650S |
| iooi |
 iooi Super Spammer
 Posted: 20:35 - 13 Jul 2009 Post subject: |
Great bit of info..
| Quote: | So, I can just set it and forget it, right? Well, not exactly. For one thing, you need to monitor the battery occasionally for correct fluid level (unless you own a sealed battery). Another problem is that of exercising the battery. Even if held at 13 volts, the unwavering voltage will allow the battery to eventually begin to sulfate. With most of these units, I recommend that you unplug the charger at least once every 60 days during seasonal storage. Allow the battery to rest for a couple of days, and then plug the charger in again. One charger that I’m aware of, the 1.5 amp Yuasa unit, has a feature found mainly on the aforementioned high priced RV chargers. It drops off the float charge and sends the battery through a complete new charge cycle every 28 days, thus eliminating the need to do that manually . There may be other motorcycle units that do that, but I’m not aware of any.
So even leaving on a Optimate is not recomended by them...
Love the bit in italic's.... Nice push of their own product. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Blue_SV650S |
 Posted: 22:29 - 14 Jul 2009 Post subject: |
| iooi wrote: | Great bit of info..
Love the bit in italic's.... Nice push of their own product. |
Interesting ... Optimate say summin different clicky
"All major battery manufacturers recommend maintaining starter batteries FULLY CHARGED during periods of non-use. OptiMate 4 is totally safe for months-long connection and maintenance of irregularly or seasonally used batteries even while still connected to the vehicle. The sophisticated charging algorithm ensures no risk of over-charging."
Who to believe?!!?
Clearly if the OP can get a someone to stick it on charge overnight every coupla weeks, then it's the best of both worlds and will have a perfectly happy battery on his return!!  ____________________ The purpose of life is to fight maturity. |
The last post was made 17 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
