tyre valve problem
Swim41
PostPosted: 20:55 - 15 Jul 2009    Post subject: tyre valve problem Reply with quote
Had a new rear BT45 fitted today.
Got the wheel home, fitted it, checked pressure. Went to use footpump to add a little air, but strangely the footpump's pressure gauge only rose slowly. I pumped the tyre up but it was harder work than usual. I tested the pump on a few other tyres and it's fine, same with my seperate pressure gauge.
Obviously the new valve isn't opening properly, although it's holding pressure fine and opens when prodded with the correct tool on the back of the gauge - but - is this likely to be dangerous? I can't get to the tyre fitters until saturday.
cheers
Yamaha XJ600N
yen_powell
PostPosted: 22:13 - 15 Jul 2009    Post subject: Reply with quote
Check to make sure the valve core is screwed all the way in. If it is and you are still having problems swap it for a new one. They are available free from your neighbours cars, but best to get one when they are asleep.
XT1200Z and a DR350 in bits
The last post was made 17 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 31.2 Kb
