r6 dash light problems?
gray84
PostPosted: 22:44 - 15 Jul 2009    Post subject: r6 dash light problems? Reply with quote
hi guys
again i really need some help as im now stuck.
on my 02 r6 i fitted front and rear led indicators with the relay.now when i fitted them the green warning light has stoped flashing.everything else is fine and ive checked the fuses,tried a diferant relay and refitted the lights to make sure there was no shorts.ive stripped the dash unit down to test the bulbs and it works.so where is the problem? please help
now the other problem is when i tested the dash light i shorted the fuel warning bulb and as these are leds soldered to a unit can i change these and just off the off chance does anyone know what bulb it is? what volt and is it 3 or 5mm?
HELP!
oh and the reason im desperate is because my mot has ran out Sad Thumbs Down
thanks
gray84
PostPosted: 07:30 - 17 Jul 2009    Post subject: Reply with quote
right ive sorted the replacing the led problem but really need help on why my indicator warning light isnt working? where can i get a wiring diagram?
cheers
Mr Hammers
PostPosted: 08:57 - 17 Jul 2009    Post subject: Reply with quote
Have you checked this thread..?
https://bikechatforums.com/viewtopic.php?t=117889
A Guide To Powerbands
gray84
PostPosted: 18:11 - 17 Jul 2009    Post subject: Reply with quote
WOW thanks. ill start there then.
gray84
PostPosted: 18:48 - 18 Jul 2009    Post subject: Reply with quote
another question. what voltage would the leds be in my clocks? maplins do 5v and 12v? i did buy some but it didnt say the voltage and when they light up in the clocks there very dull. Crying or Very sad
The last post was made 17 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 43.7 Kb
