| 3chris333 |
 3chris333 L Plate Warrior
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 14:21 - 18 Jul 2009 Post subject: |
crank seals ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| 3chris333 |
| MaybeGuy |
 Posted: 14:47 - 18 Jul 2009 Post subject: |
probably, because its over oiling the bike ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| 3chris333 |
| binge |
 binge Emo Kiddy
| Nathanmx |
 Nathanmx Derestricted Danger
| bladerunner |
 Posted: 18:56 - 18 Jul 2009 Post subject: |
Yup left hand crank seal is very likely the case! It's possible to do it without removing the engine as said before. on the RS engine it's handy if you have a pair of circlip pliers to hand as the gears are held on that way rather than with nuts ala most jap stuff. As a point of interest when you take off the balancer shaft gears (the big plastic ones) you'll see there is a line on the end of the crank,both gears and the balancer shaft itself. These are all supposed to line up when facing each other. However I rebuilt one last month and it had bad vibration due to the marks being wrong. I took the gears off,thus the balancer shaft would drop to the bottom and put a pencil down the plug hole and turned the motor to TDC and put the gears back on.......the bleedin marks were 3 or 4 teeth out!!!! so check the marks on your motor before you remove the gears.
Also if your bike seems to be getting better it's not..it's just the gearbox oil has dropped and your now going to be sucking in air through the seal and running a dry gearbox!!!!!!!!!!
A last point of note is the genuine rotax seal has a hard fiber insert on one of the sealing faces and the after market seals do not........having had an aftermarket seal fail in 1000 miles I'll be doing the same fitting job as yourself but with a genuine seal this time!!!
HTH  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| 3chris333 |
The last post was made 17 years, 81 days ago. Instead of replying here, would creating a new thread be more useful? |
