Pothole Damage?
 Topic moved: from Biking News & Rumours to General Bike Chat by G (20 Jul 2009 - 20:29)
judderman3000
PostPosted: 13:46 - 19 Jul 2009    Post subject: Pothole Damage? Reply with quote
Hi guys,
i'v been out for a ride on my hornet last week and as i was riding down a country lane coming out of a corner (below the speed limit i might add before anyone points blame at speed) and have hit a pothole. This threw my bike all over the show and made a very large metallic clunk noise which i thought not a lot of until id regained control and stopped, on inspection of the bike the pothole that i hit has caused a noticeable dent in the rear rim of the bike on the righthand side as i was banked to the right coming out of a right hand bend i can safely say this pothole was the cause of it as i check my bike over before i go on big rides out.
Does anyone know the correct procedure in claiming off the people who maintain the roads for a new rear wheel as mine is either beyond or a very costly repair which i cant afford!?!?!?
oh and iv not ridden the bike since
thanks in advance
Judd
Judd - Hornet 600 (restricted) Micron Can, Belly Pan, Custom rear end, Single seat cowl, need to sort front end out e.g. headlights and USD forks...
MaybeGuy
PostPosted: 13:51 - 19 Jul 2009    Post subject: Reply with quote
unless it was reported, and not dealt with within a reasonable amount of time, theres nothing you can do.
anyway. pothole? poor obs.
judderman3000
PostPosted: 13:55 - 19 Jul 2009    Post subject: Reply with quote
from my return vist to take pictures it has quite obviously been filled in before, so from this then im assuming that the job is either unsatisfactory or the inspection scheme of the council is faulted.
Does this give me grounds to stand on?
regards
MaybeGuy
PostPosted: 14:07 - 19 Jul 2009    Post subject: Reply with quote
theres no point in trying really. this isnt america
judderman3000
PostPosted: 14:24 - 19 Jul 2009    Post subject: Reply with quote
thats an easy one for people with the money to throw at new rear wheels to say, but i shouldn't be having to pay out for broken parts due to poor road surfaces i pay my road tax so that the councils have money to spend on traffic services which are obviously inadequate.
UnknownStuntm...
PostPosted: 14:39 - 19 Jul 2009    Post subject: Reply with quote
Contact the local council to see what they say. More than likely they'll apologise and tell you that they'll fix it within 48 hours, and that repair will be much the same as the previous one. A bodge, that is. It'll most probably be farmed out to the Highways Agency. The trouble you'll get is that the Highways Agency are Teflon shouldered, illiterate, rude scum and they'll avoid work and effort at all costs unless you kick up a major fuss.
If it were me, I'd take pictures of this hole from 3 angles, (before you can see it, first opportunity to avoid it and a close-up of it with something in there to give a sense of scale) and of the damage to your bike. Send them to the Highways Agency and the local council, with a letter and the estimated cost of repair - don't take the piss with the cost to fix either.
Do it quickly, don't muck about waiting. And let us know what happens. Thumbs Up
daemonoid
PostPosted: 15:32 - 20 Jul 2009    Post subject: Reply with quote
Or... they didn't do the inspection on time which is quite common nowadays - you can request to find out when the road was last inspected and when it last should've been inspected.
current: ducati monster 750
PostPosted: 21:26 - 20 Jul 2009    Post subject: Reply with quote
Actually, you pay 'vehicle excise duty' so that you can use your vehicle on the roads. There is no direct link between what you pay and what gets spent on the roads.
Also, you also should be keeping up good observations of the conditions you are riding in; why should the rest of us have to pay out for your rear wheel if you don't pay attention to where you're riding?
If you were to succesfully sue them, they'd have even less money to maintain the roads.
Anyway, have you reported it to the council? If you haven't, can't really complain much... someone else might suffer the same fate tomorrow. And, of course, if someone has contacted the council before and they haven't done anything then you will have more of a case to get some money out of them.
Ariel Badger
PostPosted: 21:47 - 20 Jul 2009    Post subject: Reply with quote
A bit harsh blaming the OP's obs for the damage peeps. You come out of a bend cranked over and your line is pretty well determined for you.
PostPosted: 21:58 - 20 Jul 2009    Post subject: Reply with quote
So, what if a cute kitten had been lying in the road instead?
https://www.hoax-slayer.com/images/no-bonsai-kitten.jpg
"Won't somebody think about the kittens?", as they say.
I admit I don't ride that fast on the road these days* - one of the reasons though, is that I know there's all sorts of dangers to me, my bike and from me to others.
I definitely don't ride to the point that I can't alter my line on the road - which on modern bikes tends to be pretty damn fast.
'Ride so you can stop in the distance you can see' is a common mantra that I may not follow, but does offer good advice if you don't want to damage your bike.
(*Or anywhere else, really, but that's another matter.)
In the past, when I was a lot worse off, I did crash on a ridiculous* pothole (it may have actually dented my wheel too, in retrospect), I did consider seeing what I could do to get money back, but then thought better of it. Twas my own fault for riding too fast through somewhere that I knew was likely to have a questionable road-surface.
*In Henly on Thames; the only place I've seen 'failed road' signs put up because there's so many pot holes, though this wasn't in one of those parts.
Devils Advocate
PostPosted: 06:58 - 21 Jul 2009    Post subject: Reply with quote
I had a similar event about 15 years ago in a car.Country lane,massive pothole,damaged axle and cracked alloy.Car un-driveable and stopped traffic flow.
I rang a mate who came round with a camera and we took pics straight away.Rang the breakdown recovery which proved helpful in the long run coz they acted as a witness to the size of the hole and also verified the damage/repair costs.
Rang the police and council next and vented my anger and within 1 hour they had a team there filling the hole in (probably trying to get away with liability).
After sending them a few letters detailing the incident with photos and costs,they accepted fault and paid out almost 2k.
Its not your fault you didnt see the hole in time and react,the fact is it shouldnt have been there anyway if it was deep enough to cause major damage to your vehicle.Poor observations has nothing to do with it.
You pay road tax and council tax for a reason so dont let them get away with it if your bikes damaged.
Claim for repairs,out of pocket expenses,and vehicle hire charges if you`re off the road now.
Sod what anyone else thinks about it.....CLAIM!
PostPosted: 07:52 - 21 Jul 2009    Post subject: Reply with quote
Would you say the same if you hit a toddler that was standing in the road (who of course /shouldn't/ have been there)?
I just hope you don't complain when government services don't have enough money... like, err, the the ones that repair the roads Smile.
Round here the general road surface condition is bad enough that if you don't keep your wits about you, general undulations and bumps will cause you some serious problems if you're not looking out, never mind pot-holes.
JAMSXR
PostPosted: 08:43 - 21 Jul 2009    Post subject: Reply with quote
A person/animal would be far easier to spot then a pot hole... I don't see how you can blame his observation unless you were there? On a number of occasions in the past I have had plenty more things to look out for then the possibility of a pot hole, driving through busy towns you have pedestrians crossing, high volume of traffic, buses, cyclists, cars changing lanes. I know looking ahead at the road service for hazards is important, but it’s not always possible.
Polo
PostPosted: 08:53 - 21 Jul 2009    Post subject: Reply with quote
This poor obs business is rubbish when it comes to potholes. I have been found out by many on wet days.
Supposing the pot hole is filled to the brim with water on a rainy day. Please someone explain how I avoid these - aside from leaving the bike at home.
Ta ever so.
My mum smells your fingers
daemonoid
PostPosted: 08:56 - 21 Jul 2009    Post subject: Reply with quote
Fifth gear did an article about this on last weeks show. Their point was that by claiming you may finally improve the road surface because the council will realise that fixing it is cheaper than dealing with claims. At what cost I don't know... some other service would have to be cut, or taxes increase or at least preventing £155 million going missing on MOD radios.
Devils Advocate
PostPosted: 09:20 - 21 Jul 2009    Post subject: Reply with quote
A small child standing upright in your field of vision is something quite different to a sneaky horizontal hole in the ground.Bad choice of comparisons.
My observations are good and i`m always aware of road conditions when riding but tbh i spend more time focusing further down the road than i do looking at the tarmac.A dodgy road is acceptable (just),but a universe swallowing man pit is definately NOT.
As far as this government goes i do not care anymore.I have been raped with extortional taxes,charges and bills for the last 25 years so whenever an opportunity arises to get something back,i take it without remorse or feelings.
The state of our roads has gotten out of control already and it shouldnt be OUR responsibility to report which areas are bad and which arent.The council should do their fucking jobs properly,monitor the roads,maintain them,and give us a satisfactory service for something we already pay them for.
Most of the time it`s THEM who fuck the roads up anyway after roadworks and all the digging they allow.They should have some sort of quality and safety inspection done afterwards to ensure our safety IMO.
If i ever drive into another hole,or have to swerve to avoid one that damages a vehicle of mine or puts me in harms way,or if i come a cropper due to ANY excessively bad road surface....i`ll always chase the council for the money,each and every time.
You may not agree,but hey ho,that`s life.
short1uk
PostPosted: 09:48 - 21 Jul 2009    Post subject: Reply with quote
Nowt you can do. A hole 2ft long 1ft wide and 4 inches deep destroyed the tyre on our car other week. Told council and they filled it in day after. I sent them the bill they said sod off.
They not liable as they fixed it when we reported it.
daemonoid
PostPosted: 10:05 - 21 Jul 2009    Post subject: Reply with quote
Not exactly true. Request that they tell you the last time the road was inspected, and whether anyone else had reported it. Then it's still worth a trip to small claims court. Just because they're not admitting liability immediately doesn't mean they're not liable:
https://www.potholes.co.uk/claims/step_by_step_guide
PostPosted: 10:31 - 21 Jul 2009    Post subject: Reply with quote
The toddler was wearing grey with a hat and has just fallen over.
Irrelevent really; it could be a clown juggling clubs on fire, the question is, is it a case of poor observation if you miss hit something that could damage you and your vehicle, or someone else or their property.
The answer in 99.999% of the time is 'yes' - the exception being cases like Keith mentioned once where something that had fallen from a plane hit a driver.
Motorcyclists very often seem happy to entirely blame others in these sorts of situations, an odd sitation I find when the consequences can often involve significant impairment or loss of life. A load of compensation and the belief there was "nothing I could have done" isn't that great when you will be wheel-chair bound for the rest of your life.
If you're looking down the road, you should have seen a 'unvierse swallowing man hole' when it appeared I'd say Wink.
I'm not suggesting I'm any better, but if you're willing to do-over the public's money whenever you can, then you're getting just the crappy country you're helping to make.
The council should arrange for (a current supermodel) to wake me up with a blow job every work-day. Back in the real world, they have a very limited amount of money and some pretty inefficient working packages.
Unless you're trying to make a real difference by standing for local elections or similar campaigning, you're just making the situation worse taking more money out of the system.
How many report pot holes they don't hit?
Minty:
If there was enough standing water that you can't see a pot hole, then, were it me, I'd probably be riding slow enough through it that the pot hole wasn't going to cause a problem, otherwise I suspect I'd be crashing in some other way.
JAMSXR
PostPosted: 10:57 - 21 Jul 2009    Post subject: Reply with quote
So what if you are coming round a blind corner to fined a tractor/bus taking up your road space, you swerve/move over to avoid it, this ends up sending you into a deep pot hole damaging your bike?
Thats not my problem, I pay a ridiculous amount of tax and expect a quality road surface. Unfortunately you go somewhere like Wales which has a huge Labor constituency, and hundreds of thousands have recently been spent on roads which see very little traffic!
My dad has a house in France, and I am always outstanded by the superior quality of the roads there! It's the same in Italy, miles and miles of smooth high quality roads.. Come to the UK and it's a completely different story!
PostPosted: 11:17 - 21 Jul 2009    Post subject: Reply with quote
Erm, then you've definitely got rather bad observation (or acting on those, at least) skills - we've back to being able to stop in the space you can see. What if it was a road with barbed wire fences at the sides (as quite a few around me are) and the rear of the tractor are large spikey bits, taking up all of the road?
Now you're probably dead, with no chance to sue the council either!
Again, I'm not saying I'm perfect or wouldn't end up in this situation - just that I would then try claiming there was 'nothing I could do'.
Actually, it most probably is a problem if you hit an unreported pot-hole and damage your bike Razz.
Where I live the use of the roads and specific environment they are in is very different to the many places I've been to that have much nicer roads. I'm sure, of course, a lot of it is to do with poor quality work; but that's more of an issue with our governmental system as a whole.
Polo
PostPosted: 11:18 - 21 Jul 2009    Post subject: Reply with quote
G wrote:
Minty:
So you can't avoid it then? Wink
Not everything comes down to obs, as I stated. It only takes a nasty pothole on a corner, in a downpour and things can get very ugly.
PostPosted: 11:32 - 21 Jul 2009    Post subject: Reply with quote
You have good enough observations to note that the conditions are trecherous enough that you have no idea what you're riding over. So you adjust you're riding appropriately and don't damage your vehicle - going over a pot hole isn't an issue if that's the case.
If things 'get ugly', then you're not riding appropriate to the conditions really and aren't acting on your observations.
JAMSXR
PostPosted: 11:35 - 21 Jul 2009    Post subject: Reply with quote
So you have never had to take sudden action while driving, or changed your road position as a result of the actions of another driver? Well you are pretty lucky then...
Well it's not always like that, another road user driving/riding inappropriately could cause you to swerve and hit a pot hole, which then causes you to have an accident.
iooi
PostPosted: 11:37 - 21 Jul 2009    Post subject: Reply with quote
While obbs should have picked it up. The fact is often mid corner you have no option but to take the hit.
While it could be a tractor round the corner, it could also be one comming the other way so you can't sit up to avoid, or something stopped at the side of the road, so you can't tightnen up.
As had been said in the wet, and a hole if full of water. Even the bests obbs won't pick up a hole in the road.....
As well as the fact we are advised to look where you want to go when cornering, not down at the road infront of you Wink
The last post was made 17 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.05 - MySQL Queries: 16 - Page Size: 143.71 Kb
