Chain Dilemna
Dr Nick
PostPosted: 00:19 - 09 Jun 2004    Post subject: Chain Dilemna Reply with quote
Today my chain decided to come off at 45mph, clicked down a gear and heard a crunch, then the speedo stopped working. Immediately pulled the clutch lever in and pulled over. The chain has wrapped itself around the sprocket a few times, ripping off the plastic cover that holds the speedo drive in. Hence it not working. Chain looks like it has managed to rip some metal off of the engine too and scar up my back wheel. Got a tow from my mate to his house about 5 miles away, no luck getting the sprocket off as we didn't have the right tools and didn't want to round the nut off.
Thinking about whether the gearbox could be damaged?, i'm going to order a chain and sprocket kit from bandcexpress tomorrow, Renthal hardened sprockets and an X ring 'racing' chain Wink .
Was thinking about downgearing the bike while i'm at it. 1 down at the front and 3 up at the back?, i used 'Maurices Gearing program and it seems to be upgearing it Shocked Confused . See Attachment
This bike seems to be a moneypit at the moment Crying or Very sad . Don't know whether to fix it all or just sell it as it is. What would you do in my situation Question .
Thanks in advance.
is that it
bikedudextrm
PostPosted: 00:25 - 09 Jun 2004    Post subject: Reply with quote
Last time i was out on my bike the bolt that holds the front sprocket on came loose and the front sprocket fell off, stopped at traffic lights and went to pull away, nothing there just revving. Was annoying but a had bad feeling as i thought it was my gear box Confused .
Police Tut Tut
https://www.bikepics.com/members/bikedudextrm/
Dr Nick
PostPosted: 00:26 - 09 Jun 2004    Post subject: Reply with quote
Exactly the same happened to my mate on the DT, he also thought it was gearbox, he rode his bike home with no nut holding the front sprocket on Shocked .
is that it
Flip
PostPosted: 00:34 - 09 Jun 2004    Post subject: Reply with quote
If it's a money pit, won't that be obvious when people come to veiw it? (does that make sense?) Run it in to the ground. Enjoy it Twisted Evil Well thats what I would do.
GSXR
PostPosted: 00:37 - 09 Jun 2004    Post subject: Reply with quote
I don't know what's gping on with the gearing calculator thingy but if it's of interest I make the correct figures to be (to the nearest mph):
30 > 26
60 > 52
70 > 61
100 > 86
130 > 113
160 > 139
Overall reduction in gearing 13.33%
GSXR | Ian
| 1991 GSX-R 1100M | 1994 XR600R | 1965 BSA C15T | 1970 Woman | 2001 Daughter | 1989 Leathers |
PostPosted: 01:03 - 09 Jun 2004    Post subject: Reply with quote
Check that the chain has not taken a chunk out of the engine, or damaged the swinging arm.
Chains coming off can be expensive.
Phoenix
Twisted Firestarter
PostPosted: 01:05 - 09 Jun 2004    Post subject: Reply with quote
Ditto, where it managed to 'rip' some metal off the engine check it's not cracked the engine casing. This has happened to my VFR and the resulting damage (loss of two mounting points) now means I've got to drop the engine out to have it welded.
Frost
PostPosted: 01:35 - 09 Jun 2004    Post subject: Reply with quote
yup that gear ratio program appears to be borked Razz
It appears to be calculating the gear ratio as:
rear sprocket / Front sprocket
where as it should be the other way around, hence when your putting in lower gearing its telling you your gearing up.
Attached is an excel spread sheet which i made to calculate the effects of upgearing on my bike. just pop in your ratios and it should calculate everything for you.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 02:22 - 09 Jun 2004    Post subject: Reply with quote
The gearing program isn't borked, it's just not doing what you think it is. It calculates the bikes speedo error after changing the gearing. Eg in that screenshot your bike would be indicating 34.6 while you were actually doing 30mph. HTH
Stew
If it's good enough for top race teams...
PostPosted: 09:40 - 09 Jun 2004    Post subject: Reply with quote
Mau, perhaps you should rewrite it so that it calculates new speeds (actual speed) after gearing changes rather than calculating speedo error after changing sprockets. Thumbs Up
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
zaknafien
PostPosted: 12:17 - 09 Jun 2004    Post subject: Reply with quote
Just add another column and then you get both, much more convenient. Razz
Go on mau, you know you want to make another one for me to break. Razz
02 Firestorm.
Dr Nick
PostPosted: 18:28 - 09 Jun 2004    Post subject: Reply with quote
Well after a bit of tugging and cursing, managed to get the chain and sprocket off, would itself up pretty tight.
Engine casing isn't damaged Smile, just the casing that hold the speedo drive in has been smashed to bits. Don't think i'll bother downgearing the hornet for the time being. Where would you suggest to get Renthal CHain and Sprocket kits from Question .
Ordered an 020 today as it needs a new rear tyre and had the wheel off etc. £121 fitted. Is this a good price?
is that it
PostPosted: 19:24 - 09 Jun 2004    Post subject: Reply with quote
Cheapest place I have found for chain and sprocket kits (although never bought any alloy sprockets) is Trade Direct.
Dr Nick
PostPosted: 19:26 - 09 Jun 2004    Post subject: Reply with quote
Got a URL?, i googled it, but it comes up with ads, and domains that haven't been purchased.
Thanks
is that it
PostPosted: 20:14 - 09 Jun 2004    Post subject: Reply with quote
No URL, but try phoning 08705 134859 .
rizo-sri200
PostPosted: 23:13 - 09 Jun 2004    Post subject: Reply with quote
it happend on my dt125.
it cracked my engine casing where the clutch pushrod enters the crankcase and as a result my clutch return spring wouldnt do its job due there being no lug for it to latch too...
Cost me £65 to get a small lug welded to hold spring in place Rolling Eyes
swift kick to the wing mirror puts em straight..
98' Bandit 600 with Slip on
EuropeanNC30R...
Gay Hairdresser
PostPosted: 02:46 - 14 Jun 2004    Post subject: Reply with quote
Try www.mauriceb.btinternet.co.uk/Sprockets.exe for an improved version of that gearing calculator.
Dr Nick
PostPosted: 02:48 - 14 Jun 2004    Post subject: Reply with quote
Shocked https://the-npf.com/stuff/ooo.JPG
is that it
EuropeanNC30R...
Gay Hairdresser
PostPosted: 02:52 - 14 Jun 2004    Post subject: Reply with quote
Hmmm that's interesting one of the label's is slightly chopped on your monitor, it wasn't on both my 14.1" TFT and 17" CRT Confused
Dr Nick
PostPosted: 03:09 - 14 Jun 2004    Post subject: Reply with quote
I have a 17" CRT running 1280 x 960 resolution.
is that it
EuropeanNC30R...
Gay Hairdresser
PostPosted: 03:22 - 14 Jun 2004    Post subject: Reply with quote
When you get chance, could you try downloading it again from that location and see if it's fixed? (I'm looking at the 'e' in the 'Speedo Percentage error' label. Cheers.
Dr Nick
PostPosted: 03:29 - 14 Jun 2004    Post subject: Reply with quote
Yep, looks like you've sorted it Smile .
is that it
Demonic69
The Pink Rhino
PostPosted: 04:21 - 14 Jun 2004    Post subject: Reply with quote
They both look the same to me Very Happy
Back on a Blade. Just feels so right.
Dr Nick
PostPosted: 12:40 - 14 Jun 2004    Post subject: Reply with quote
Razz
is that it
The last post was made 22 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 123.89 Kb
