| Billing |
 Billing World Chat Champion
| samj6 |
 samj6 Renault 5 Driver
| Blue_SV650S |
 Posted: 22:54 - 19 Jul 2009 Post subject: |
I don't mean to sound condescending, but you did remember to turn the choke off right???  ____________________ The purpose of life is to fight maturity. |
| Billing |
| Nipedley |
 Nipedley Scooby Slapper
 Posted: 23:36 - 19 Jul 2009 Post subject: |
Headwinds seriously decrease the performance of the CG if you're doing 40+ speeds. I use the dual carriageway at least four times a week, the same hill on a good day can be 60, on a bad day can be 50-55, and if its seriously windy can be as low as 43mph in a low gear some times.
I don't know if this is the cause of your problem but it's something to consider  |
| Howling TerrorOutOfOffice |
| rob_scott92 |
 rob_scott92 Could Be A Chat Bot
 Posted: 01:18 - 20 Jul 2009 Post subject: |
i had similar problems yesterday, i started thinking that it was the brakes sticking , but turned out just to be the wind (has a drastic effect on light bikes). if its definately not the wind causing you a problem it could be a slight fuelling problem maybe cleaning out the carb would sort that but i wouldn't go taking it apart until you know for sure .
Rob  |
| Billing |
 Posted: 01:26 - 20 Jul 2009 Post subject: |
its most certainly not wind, its an engine problem as i was going down hill at the time and there was very little wind. I parked up and revved it up, and it got to the limiter and 'bounced' very slowly :S I'm wondering if some water got into the carb somehow (it was very rainy yesterday) and its blocked the jet now. I have no air line, and no carb cleaner, so cant clean the carb out, may strip it down and as i do that itll dislodge any crap in there  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| Billing |
 Posted: 16:09 - 20 Jul 2009 Post subject: |
stripped the carb down, all the jets are clear, so im wondering if the emulsion tube has gone oval and is now letting too much fuel through, the problem seems to be at the top end of the rev range, when on saturday there was no problem at all the only other thing i can think of would be a knackered coil or something like rings/burn out valve. anyone got any ideas? ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| Martay |
 Martay World Chat Champion
 Posted: 17:29 - 20 Jul 2009 Post subject: |
Is it possible one of your valves is sticking, or has burned out? If you want a hand with anything, drop us a ring  ____________________ Eat well, poo hard
Drives: Cavalier 2.0 16v
Rides: Slightly ratted Honda City Express  |
The last post was made 17 years, 105 days ago. Instead of replying here, would creating a new thread be more useful? |
