Please help me with Honda CG125 question
ticklemeelmo
PostPosted: 22:33 - 21 Jul 2009    Post subject: Please help me with Honda CG125 question Reply with quote
This might be a really stupid question but how do you remove the large plug with a groove in it (i think it is called the pivot shaft) behind which are the cam followers. It has a small hole in it but I can't seem to get it out.
I need to remove the cam followers and put them in a new bore. Any help would be great.
Thanks
Thanks.
dextersaurus
PostPosted: 09:28 - 22 Jul 2009    Post subject: Reply with quote
Big ass screwdriver?
Edit: Assuming it's that one...
ticklemeelmo
PostPosted: 17:20 - 22 Jul 2009    Post subject: Reply with quote
But the grove is far to shallow to be able to turn it. Or does it prise out?
Thanks.
dextersaurus
PostPosted: 21:46 - 22 Jul 2009    Post subject: Reply with quote
If you use a really wide screwdriver it shouldn't be a problem.
And no... doesn't prise out.
Try it out with a screwdriver and see how you get on Thumbs Up
Dunc
PostPosted: 05:34 - 23 Jul 2009    Post subject: Reply with quote
If it's the bit below the red outline (not my picture, just one I found) and it's supposed to unscrew, then maybe you could try a 50p and molegrips.
https://www.pakwheels.com/images/forums/2008/11/16/pdfrr_R75_PakWheels(com).jpg
Mark65
PostPosted: 08:06 - 23 Jul 2009    Post subject: Reply with quote
Yes a large washer will do it , i have one for when i checked the valves on my ybr, a spot on fit. Try a couple till you get the one that fits snug, mine came off without any effort really.
Mark
dextersaurus
PostPosted: 16:23 - 25 Jul 2009    Post subject: Reply with quote
so did you get it out then?
Dunc
ticklemeelmo
PostPosted: 22:22 - 25 Jul 2009    Post subject: Reply with quote
Yep got it out. I soaked it in WD40 overnight and used a big screwdriver to turn it. It did prise out though it is a plug with a rubber o ring on it. What holds it in place is the bolt that goes through it from above.
Thanks for all your help. Smile
Thanks.
The last post was made 16 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 55.46 Kb
