Removing 2002 Honda CBR600F Sport Restrictor
dfgdfg1988
PostPosted: 14:12 - 22 Jul 2009    Post subject: Removing 2002 Honda CBR600F Sport Restrictor Reply with quote
Hey, i got my cbr restricted to 33bhp, but want to remove it.
does anyone know how to remove the restrictor.
but this bike has a fuel injection system on it.
cheers guys! Thumbs Up
Chriss
PostPosted: 11:40 - 24 Jul 2009    Post subject: Reply with quote
Hi, not sure on the specifics for this bike, but I have found FI bikes are restricted normally in one of two ways (there are others).
Throttle stop and the ECU itself. Did you get the bike restricted? Does it have a certificate? The Triumph one from memory specifies how it was restricted. How far round does your throttle go? Have you checked to see if there is any mechanical stop (it'll probably be by the throttle bodies).
If it's ECU, you should have a 'spare' one.
I'm sure there are lots of other ways you can restrict a FI bike though.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
carlperkins00...
PostPosted: 11:43 - 25 Jul 2009    Post subject: Reply with quote
if its fuel injected it will be a throttle stop at the end of the throttle cable. this reduces the amount the throttle can be opened.
just follow the throttle cable to the end and unbolt the stop that is preventing it from moving all the way round...
then in the airbox you will have 4 washers which you just need to find and pull out. job done Thumbs Up
if its a fuel injected older model, then there will just be 4 washers in the carb rubbers between the carbs and engine.
hornet example...
https://i1003.photobucket.com/albums/af151/carlperkins001/restrictorpic.jpg
take off tank, airbox and undo the clamps on the carb rubbers, lift the carbs out the way and pull the washers out.
if you were given a CDI unit when the bike was restricted then you need to put that one in. if you werent given one then the CDi is fine.
Hope this helps. Carl. Thumbs Up Very Happy
The last post was made 16 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 36.15 Kb
