Any keen gardeners ?
B10Hazard
PostPosted: 01:20 - 23 Jul 2009    Post subject: Any keen gardeners ? Reply with quote
Okay I have a somewhat exotic plant growing
I noticed this morning the lower leaves are going quite a yellow colour and are sort of curling up?
Over watering? Over feeding ? Not getting enough light to them ?
The symptoms are looking towards root rot
Im a little lost
EDIT : The rest of the plant seems to be nice and healthy. . .
No longer any socks
PostPosted: 01:31 - 23 Jul 2009    Post subject: Re: Any keen gardeners ? Reply with quote
Sounds like over feeding or MG deficiency. Over feeding the edges of the leaves curl in and look 'burnt', mg deficiency the leaves turn yellow and edges curl in a bit.
Depends what you're growing and what you're feeding it. Unlikely to be over watering. Do the plants need potting up?
B10Hazard
PostPosted: 01:36 - 23 Jul 2009    Post subject: Reply with quote
It doesnt travel up the plant and cause really bad damage does it ?
And please dont say that its a killer Confused
No longer any socks
PostPosted: 01:54 - 23 Jul 2009    Post subject: Reply with quote
Neither do bad damage, leaves should regain normal colour when the problem is sorted. If it's MG deficiency then you need to add epsom salts when watering, about 15g per 5 litres of water. If it's over feeding then if you've overfeed by a lot then flush the soil through or if it's only slightly over fed then the plants should be ok if you don't do anything other than feed them less.
What are you growing? Razz
B10Hazard
PostPosted: 02:17 - 23 Jul 2009    Post subject: Reply with quote
TRYING TO GROW lol
A canabis plant . . . .
Tried and failed before.
Cool
No longer any socks
PostPosted: 02:27 - 23 Jul 2009    Post subject: Reply with quote
How old are the plants cos you shouldn't be feeding them anything until they're flowering.
Walloper
PostPosted: 04:56 - 23 Jul 2009    Post subject: Reply with quote
That's not legal.... Police Shocked Laughing
flamy
PostPosted: 10:42 - 23 Jul 2009    Post subject: Reply with quote
my chili plants started getting slightly yellow leaves, someone told me to use tomato feed which seemed to work a treat.
Current: GSXR 750 K6 Previous: R1, R6, ZXR400, NSR125 Next: Ducati 848 or 999
B10Hazard
PostPosted: 11:18 - 23 Jul 2009    Post subject: Reply with quote
There just starting to flower.
This morning the two yellow leaves have fell off and the leaves above seem to be going back to there normal green self.
Anybody got any experience or tips to share that may help . .
No longer any socks
Dragonfly
PostPosted: 11:50 - 23 Jul 2009    Post subject: Reply with quote
Yellow leaves usually mean water logged, to much water in plant. Are we actually talking about marijuanna plants? I recommend
Ebay Link
(does wonders on roses to but will kill some other plants)
good stuff. When its big enough get the bloom one for budding.
Ebay Link
so I hear anyway Shifty
Ok if we arnt talking about that then just stop watering the weird plant so much and post a pic.
All the breast.
Muzza on Binge:
PostPosted: 21:03 - 23 Jul 2009    Post subject: Reply with quote
Be very surprised if plant damage is caused by over watering as cannabis is a weed, so is very resilient.
You want to use BioBizz to feed the plants, I would be very cautious about using imitations like that Ionic stuff. If you've just gone into 12/12 then start giving them 1ml of each plant feed. Smile
Is it from seed or from a cutting?
Watch out for the stretch!!
Dragonfly
PostPosted: 22:45 - 23 Jul 2009    Post subject: Reply with quote
If its a cutting use the ionics hormone rooting gel and not the powder from garden centres its crap.
If its budding it should have yellow leaves ( bottom fan leaves)on it as it takes all the sugars and the nutients out of the leaves to go to the bud, just let them fall off.
When I said water logged I noticed some of my roses had yellow leaves and thats what that means. Watch for small spiders and greenfly. Let the plant use all its water and not have it like a swamp all the time.
Room temperature water also as to cold shocks the plant. Do not use baby bio on anything. Big enough pots also dont want to choke the roots your plant will be smaller and no good.
when you go to also pot in a new bigger roomy pot cut the root at the bottom, just slash it in small places not masacar it, roots will multiply after you re pot.
you growing outside or in?
All the breast.
Muzza on Binge:
PostPosted: 22:58 - 23 Jul 2009    Post subject: Reply with quote
No idea about roses but with cannabis, fan leaves shouldn't go yellow at all and there shouldn't be any leaves falling off. Confused The leaves in the buds will start to turn yellow and dry out towards the ends of flowering, which is still a good couple of months away if he's just put them into 12/12
pablouk
PostPosted: 10:19 - 24 Jul 2009    Post subject: Reply with quote
What Dragonfly said. Too much feed or overwatered. Those sorts of plants make sure you let the soil dry out( half inch down) I only water about mug & half of water every 2 or 3 days.
Keeping The Nation Pissed
Do not anticipate trouble or worry about what may never happen. Keep in the sunlight. ~Benjamin Franklin
The last post was made 17 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 84.39 Kb
