Exhaust made it slower
stirlinggaz
PostPosted: 06:11 - 23 Jul 2009    Post subject: Reply with quote
hi,
perhaps it might be an idea to look at the jetting?
if youve upgraded the exhaust & airfilter, youve messed around with air/fuel & will pobably need a bigger main jet, to let more fuel flow at full throttle.
cheers,
GAZ
PostPosted: 13:04 - 23 Jul 2009    Post subject: Reply with quote
As above.
However most exhaust will lose you power in one area to gain it in another. With a normal bike you just change gear to make sure you are at the rpm where the power is. With a scooter you might need to play around with the weights on the clutch to get it to allow more revs at the same speed (ie, not lock up until a higher speed).
Plenty on here know WAY more about scooter transmissions than me so hopefully one of them will be along soon.
greenman
PostPosted: 15:06 - 23 Jul 2009    Post subject: Reply with quote
raise the needle in the carb 1 notch if it runs a little better ,you need a bigger jet ,back of thrashing it because its running weak
PostPosted: 15:58 - 23 Jul 2009    Post subject: Reply with quote
Wilson123 wrote:
I got some rollers with the exhaust but I didn't fit them, I'll have to fit them and see how they go
You need to fit them, this will be what is causing you the most problems. As I said in another thread, remove your main jet to find out what size it is, it's very easy.
The Artist
PostPosted: 00:12 - 24 Jul 2009    Post subject: Reply with quote
How about you STOP BULLSHITTING about your frickin top speed tard
lukamon
PostPosted: 00:30 - 24 Jul 2009    Post subject: Reply with quote
Wilson123 wrote:
Fitted those rollers earlier, 6.6grams and it's fucking rapid!
Still does 65 on a straight even with the lighter rollers Very Happy
I took the silencing shit out of the exhaust too so it sounds evil!
I didn't have time to fuck around with the carb so I'm ringing PM Tuning tomorrow and seeing which jet size they recommend for my bike with it's components
£80 well spent Very Happy
please, don't change you bike. you deserve it and it deserves you Thumbs Up
killa wrote: Im an ass man myself
The Artist
PostPosted: 01:32 - 24 Jul 2009    Post subject: Reply with quote
Wilson123 wrote:
Yes because my idea of a good time is lying about the top speed of my moped
Fucking idiot
The fucked up thing is, most ped owners do!
Didn't say you had a good time just it seems to make you feel a little better inside or something.
The Artist
PostPosted: 01:46 - 24 Jul 2009    Post subject: Reply with quote
Just the sheer amount of people on here (ped owners) that claim to have stupidly fast peds doing unreal speeds with multi coloured powerbands and nitrous.
I had nitrous when I had ped and it worked for about 5 seconds before all the seals around the crankcase popped out.
baldy
PostPosted: 02:04 - 24 Jul 2009    Post subject: Reply with quote
You may not have to up jet the carb, it depends on the exhaust. When my brother fitted a k&n and sports pipe he didn't need to change the jets.
baldy
PostPosted: 02:38 - 24 Jul 2009    Post subject: Reply with quote
if you take the sparkplug out the end should be a coffee brown colour. If it's black it needs a smaller jet, if it's white or grey it needs a bigger jet. Post a pic of the plug and i'll tell you what jet you need.
stevo as b4
PostPosted: 22:36 - 25 Jul 2009    Post subject: Reply with quote
My std SF100 did what i belive to be true 54mph on the flat, using a trip computer as my verification. The indicated speed is 56-58mph, and downhill it would indicate 63-65mph, but really only about 58-60mph.
You definately needed the lighter rollers, and depending on the pipe, stronger clutch springs too. The jetting will never be perfect with any aftermarket pipe, and so re-jetting is always a good idea, if you know what your doing. I find scooters hard to set up personally, so id pay to use a dyno every time tbh.
Whatever you do don't change the Variator to a Malossi one, as they are no good at all on the 100cc.
Keeping the std carb, is also best i think on this motor, as if you go bigger you lose power and acceleration, for a tiny gain at the top. The engine's don't tune very well, so after a good pipe and set up to suit, it's best to call it a day! I'd have been happy with this set up and the VFM/ expense to power gains involved.
I found out £600 later that 11.8bhp was as much as i could get out of the motor, and the only mod left was a 120cc kit that might have added another 1-1.5bhp at the most. At the beginning i was thinking id get an easy 15bhp out of it, but i just ended up looking a tool tbh!
SoND
PostPosted: 16:05 - 26 Jul 2009    Post subject: Reply with quote
Feeling better = good times.
Most ped owners don't realise that speedos are inaccurate.
The last post was made 16 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.66 - MySQL Queries: 13 - Page Size: 128.07 Kb
