| dave_225 |
 dave_225 Two Stroke Sniffer
 Posted: 09:30 - 24 Jul 2009 Post subject: |
The revs issue sounds like an air leak. Possibly a cracked carb rubber (ie, the rubber block between the carb and the engine), possibly worn crank seals (although I wouldn't expect it to rev that high if they were just worn), possibly a leak elsewhere.
As to the clutch cable, the first and main place to adjust it is on the left of the engine. Once that is correct adjust it at the lever.
| dave_225 |
| dave_225 |
 Posted: 10:11 - 24 Jul 2009 Post subject: |
The big black knob is the idle speed. All it does is push on an angled bit of the carb slide as you screw it in, lifting up the slide.
To me the bogging down as you try and move off sounds like it is a bit lean at low revs / just as you open the throttle.
I would reset everything back to stock (check the idle mixture screw), and make sure everything is clean (might well be worth draining the tank and carb, and checking for water in the petrol).
| dave_225 |
| tutton |
 tutton World Chat Champion
| dave_225 |
| tutton |
 Posted: 11:04 - 24 Jul 2009 Post subject: |
Next step is to do what keith has suggested, get the carb open and set back to original settings.
I have a brand new rs125 haynes manual you might be intrested in  ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
Current: '02 ZX636 A1P '51 CCM R30 |
| dave_225 |
| dave_225 |
| dave_225 |
| dave_225 |
 Posted: 11:32 - 24 Jul 2009 Post subject: |
Which carb do you have?
On the phbh carb (fitted to most RS125s, certainly new for the last decade or so until the latest version) the pipe goes onto the carb on a banjo shaped bit with a bolt through the middle of it. Turn the petrol off and remove the bolt and then take the cover off and you should find the filter which is a mesh disk.
On the VHSB carbs (fitted to older RS125s, often fitted as an upgrade to newer ones) the filter is a mesh tube that goes in where there is a bolt just under the pipe the fuel goes into.
| dave_225 |
| dave_225 |
| dave_225 |
| dave_225 |
| dave_225 |
The last post was made 16 years, 269 days ago. Instead of replying here, would creating a new thread be more useful? |
