which way is the arrow ment to point on a 2st thumper?
spitfire123
PostPosted: 14:03 - 25 Jul 2009    Post subject: which way is the arrow ment to point on a 2st thumper? Reply with quote
hi all,
doing a complete rebuild on the mito.
was wondering...does the arrow engraved on the piston ment to point towards the exxhaust port or the inlet/powervalve port?
i allways thought it was exhaust.
just wanted to make sure before it all goes back together.
cheers Thumbs Up
You won't be able to eat my dust......As it'll settle before you get there.
The Artist
PostPosted: 14:10 - 25 Jul 2009    Post subject: Reply with quote
Exhaust port.
It's the flow of air/fuel
spitfire123
PostPosted: 14:38 - 25 Jul 2009    Post subject: Reply with quote
allymoss wrote:
Exhaust port.
yep thought so.
was 99% sure just i took it apart about a month ago and have been focasing on other things scince Laughing
cheers Thumbs Up
swampy
PostPosted: 21:00 - 25 Jul 2009    Post subject: Reply with quote
As a side note to the above, the other way to check which way round your piston should go is to look at the the little stops on the ring grooves. These should face the inlet side of the barrel, otherwise you could risk getting the ends of the piston rings getting trapped in the exhaust port... Thumbs Up
The last post was made 16 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 3.03 - MySQL Queries: 13 - Page Size: 39.74 Kb
