Just fitted this lot to my XR...
Sparks!
Sir Tart-a-lot
PostPosted: 17:45 - 25 Jul 2009    Post subject: Just fitted this lot to my XR... Reply with quote
Well I've only ridden it once and various bits broke Laughing so since the last time I rode I've fitted
Tag T2 fat bars with WRP fat bar clamp adaptors
Easton grips with grip donuts
New decomp lever + cable
New Kawasaki KX style kill switch (honda ones SUCK)
EGO Barkbusters (well reccomended, look good and they are SOLID)
Had to take all the throttle cables off today and lube them all up as wel as tighten almost every bolt on the bike, previous owner was good at cleaning but not at checking bolts for tightness! The whole front end was loose which I found out the first day I rode when I fell off and twisted the whole front end up Laughing Also had to bleed both brakes with fresh fluid, the front caliper is going to need cleaning properly soon as its binding Rolling Eyes and a full service is also needed... but it's getting there.
I'm having some issues with the throttle still and with the clutch, but it should be rideable for now.
I'm almost 80% sure there was practically no oil in it when the prev owner sold it to me Rolling Eyes as I've just had to put in half a litre and im sure they only hold about a litre in total.... hope no lasting damage!
All in all its now good as new, feels good and rides well, love the handlebars and the barkbusters on the road, can't wait to go trail riding tomorow and hope nothing else breaks! Laughing
It's still a farmers tractor, but it's growing on me Laughing
https://img196.yfrog.com/img196/8906/myxrnewbarsetc.jpg
p.s I appreciate that the above picture is pretty much useless at showing anything but the barkbusters, but they do look nice Laughing
p.p.s does anyone know where to get shorty levers for my bike? I hate long ones anyway but they are too long for the barkbusters so really need some shorty ones...
Hazylogic
PostPosted: 21:46 - 25 Jul 2009    Post subject: Reply with quote
I like.
KevTM
PostPosted: 22:13 - 25 Jul 2009    Post subject: Reply with quote
Nicely done! looks pretty good from that pic.
Trail/Supermoto/etc are the way forward Thumbs Up
Had a few 125 trail bikes before doing my test and lusted after a DR350SE at the time, thought I'd have one once I passed my test but ended up with road bikes up until last week when I got a KLX650.. probably the best move I made.. ever! Laughing
Have fun on it and be sure to post some pics of you (well, your bike Laughing) on your trails Cool
joe black
PostPosted: 18:49 - 26 Jul 2009    Post subject: Reply with quote
1.8 ltrs with oil filter change.
Quote Me Happy
PostPosted: 19:19 - 26 Jul 2009    Post subject: Reply with quote
Nice - be careful how you check the oil level though, it's a bit of a git to get an accurate reading, doing it wrong often leads to it showing low on the dipstick. I found the best way was to do it after a ride and properly warm. Just stop and let it idle bolt upright and quickly check the level.
Sparks!
Sir Tart-a-lot
PostPosted: 21:40 - 26 Jul 2009    Post subject: Reply with quote
Check the level whilst it's idling? I did check it immediately after turning it off at one point and it read nearer the max mark on the dipstick, it did seem a bit of a crap method of checking oil levels, not entirely sure if the level is right.. going to do a change this week anyways so will use your method I guess.
Had my first proper day trail riding today, fukin awesome is all I can say! Bike broke as soon as I hit the first trail, gear lever spline has chewed itself up, we tried to bodge it a few times (thanks bluesv and a1trackdays!) in the end we just stuck it in 3rd and I rode everywhere in third lol, suprisingly torquey bike so pulling away wasnt too much of a problem, just the road bits a bit annoying and the tighter muddier section towards end of day meant I had to go slightly faster than I might have wanted to Laughing
I quite like my suspension Mr. Green
Eddie Hitler
PostPosted: 22:11 - 26 Jul 2009    Post subject: Reply with quote
If you have any questions about these bikes.. feel free. Spent almost 3 years with mine. Laughing
The gear shafts are rubbish on the XRs. The splines on mine smoothed away after 15k miles. After various bodges I finally took it to a motorbike racing garage who drilled a whole between the shaft and the gear lever, then tapped some metal in. Has been brilliant ever since.
Oil on these can be tricky. The way I have always done it is get the bike upright, let it idle for a few minutes then check the levels, then top up. I then double check after my ride, never had any issues.
Sparks!
Sir Tart-a-lot
PostPosted: 22:17 - 26 Jul 2009    Post subject: Reply with quote
I'm gonna get it welded on! That'll teach it to break on me Mr. Green Mr. Green ride it till lever snaps then will have to either weld a new one on or change the spline which is a bastid of a job
Sparks!
Sir Tart-a-lot
PostPosted: 18:09 - 27 Jul 2009    Post subject: Reply with quote
Is the front sprocket meant to wobble and move back and forth on the spline? Doesn't seem right to me, like there is a washer or plate missing? Spline and sprocket are both fine as is the locking plate, just seems a lot of play in it, normal?
Eddie Hitler
PostPosted: 16:19 - 28 Jul 2009    Post subject: Reply with quote
Completely, mine wobbles slightly. Ensure the 2 bolts are secure and you will be fine. Thumbs Up
tatters
Exxon Valdez
PostPosted: 19:25 - 28 Jul 2009    Post subject: Reply with quote
Same on my CRM 250 and last XR650R
baldy
PostPosted: 20:03 - 29 Jul 2009    Post subject: Reply with quote
To stop the brakes binding, put a bit of copper slip behind the dust seal when you rebuild them. They are a bugger for seizing, mine is anyway.
The last post was made 17 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 76.46 Kb
