The end of the spark plug?
Bike Chat Forums Index -> Biking News & Rumours Goto page 1, 2  Next
multijoy
PostPosted: 08:11 - 22 Jul 2009    Post subject: The end of the spark plug? Reply with quote
T'article
The interesting stuff is down towards the bottom, but the long & short is that researchers have managed to run a 4 cylinder research engine using laser ignition rather than spark plugs. The principle to the engine remains the same, but the spark is significantly larger and would allow the engine to run with a much leaner mixture. You'd also lose the HT run to the cylinders.
It remains to be seen whether you'll be able to bump start it, and whether potential blindness is preferable to HT shocks when fettling...
[edited for added typos!]
D O G
PostPosted: 09:06 - 22 Jul 2009    Post subject: Reply with quote
When the laser failed, that would be it tho - all four cylinders would stop. Suspect it would go from working properly to total failure - unlike plugs which degrade.
Definitely has other benefits though.
baldy
PostPosted: 15:02 - 26 Jul 2009    Post subject: Reply with quote
What happens when you get a carbon build up on the laser?
Timmeh
PostPosted: 19:16 - 26 Jul 2009    Post subject: Reply with quote
it breaks?
More worringly if you've got a laser capable of igniting petrol vapour how long before some nutcase dismantles an engine and starts pointing it at petrol stations?
Mr Hammers
PostPosted: 09:45 - 27 Jul 2009    Post subject: Reply with quote
I doubt holding a laser in the palm of your hand will be as effective as a spark plug in a good streetfight.
A Guide To Powerbands
baldy
PostPosted: 02:54 - 29 Jul 2009    Post subject: Reply with quote
How will people piss the missus of instead of asking her to hold the plug while you crank it over?
I don't think a laser will be as argument inducing as a plug.
dodgydog
PostPosted: 10:54 - 11 Oct 2009    Post subject: Reply with quote
Did you never see Star Wars?? Very Happy
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
Didge
PostPosted: 20:56 - 16 Oct 2009    Post subject: Re: The end of the spark plug? Reply with quote
multijoy wrote:
T'article
I'm rating your post purely for managing to use the word 'fettling', which is one of my all-time favourites. Thumbs Up Wink
Mystery
PostPosted: 19:03 - 17 Oct 2009    Post subject: Reply with quote
i think i would rather have a spark plug than the laser but if they work out all the tweeks then it might be worth having though, who knows
EUMP
PostPosted: 19:25 - 21 Oct 2009    Post subject: Reply with quote
Ahhh, interestinggg.. remote control blow things up laser Smile
C.B.T - Expired
MOD1 04/08/10
MOD2 10/08/10
Pussy Magnet
PostPosted: 16:00 - 22 Oct 2009    Post subject: Reply with quote
they say they will do all these new high tec things but it will never happen the trusty spark plug will never be faded out!
c_dug
PostPosted: 13:04 - 30 Oct 2009    Post subject: Reply with quote
Electric engines Wink
c_dug
oldbiker
PostPosted: 21:23 - 16 Nov 2009    Post subject: Reply with quote
Laser ignition sounds like an interesting idea. but It will only catch on with the engine manufacturers when one of two things happens;
1, it becomes cheaper than spark plugs, or
2, some expert convinces the government that it`s a good idea.
would you still be able to take a reading from the new laser plug to check timing and mixture?
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
PostPosted: 21:34 - 16 Nov 2009    Post subject: Reply with quote
You could probably plug in a fibre optic coupling and it would act as its own strobe.
I'd rather have a Tesla ignition though.
Itchy
PostPosted: 21:38 - 16 Nov 2009    Post subject: Reply with quote
From an adventure biking perspective this would be good, in that you can retard or advance the ignition easily by lengthening the optical fibre or shortening it...
Hence you could get high compression engines running in low octane environments, in Russia it went down to fifty octaine,
In South America it can go down to single figures,
In central Asia octane is irrelevant its just petrol scooped out of a barrel take it or leave it.
oldbiker
PostPosted: 22:02 - 16 Nov 2009    Post subject: Reply with quote
light travels at approximately 186025.25 miles per second, how long would your fiber optic lead need to be Confused
and would cutting or adding a few feet, to say a 300mm length make much difference to the timing Confused
surly the timing on such an ignition could be mapped electronically or have I missed something Wink
There is a gap of 1 year, 155 days between these two posts...
multijoy
PostPosted: 14:40 - 21 Apr 2011    Post subject: Reply with quote
https://scienceblog.com/44560/laser-sparks-revolution-in-internal-combustion-engines/
An actual development, at risk of dragging the thread back from the dead!
Glenben92
PostPosted: 15:23 - 21 Apr 2011    Post subject: Reply with quote
It'll be a novelty high performance show off feature for many years before it would be considered for "proper" use. I'd prefer sparkies personally because as it's been mentioned above, laser breaks... bike stops. Plugs degrade. Even if one DID fail, you can still get home on the others
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
UnknownStuntm...
PostPosted: 15:26 - 21 Apr 2011    Post subject: Reply with quote
That's great.
But I don't see where the shark goes?
doggone
PostPosted: 17:49 - 21 Apr 2011    Post subject: Reply with quote
Why can't petrol work using the diesel engine principal and ignite the mix by pressure alone?
I guess because petrol is too volatile.
PostPosted: 18:10 - 21 Apr 2011    Post subject: Reply with quote
It can. Called detonation and does loads of damage.
I presume that petrol under pressure becomes explosive while diesel just triggers a burn.
I would prefer that they just used spark plugs in a diesel to properly control the combustion Wink .
The Artist
PostPosted: 19:00 - 21 Apr 2011    Post subject: Reply with quote
Kickstart wrote:
ge.
Get a syringe in a vice, take the plunger out, seal the tip and put a little bit of petrol in. Put the plunger back in the top and hit with a hammer and the petrol will ignite and fire the plunger out the top.
John933
PostPosted: 19:13 - 21 Apr 2011    Post subject: Reply with quote
If by mistake you start to fill up a diesel car with petrol, then say bollox. Stop and then get as much diesel in to the car as you car. To try and dilute the mixture. You'll be surprised just how well the engine runs. Guess how I know this?
John933
My trip
PostPosted: 20:23 - 21 Apr 2011    Post subject: Reply with quote
Depends on the car. Do it with many modern common rail ones and you will kill the pump (time for an insurance claim).
Used to be the thing to do with diesels in winter though to avoid problems with the fuel going waxy.
The last post was made 15 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 131.55 Kb
