Winter storage
Jon-W
PostPosted: 11:10 - 27 Jul 2009    Post subject: Winter storage Reply with quote
As the summer is looking pretty hopeless this year (constant rain) and the winter is looming I was wondering what people reccomend doing to take a motorcycle off the road for the winter? Is it a good idea to run it now and again? Any tips would be appreciated.
Bendy
Mrs Sensible
PostPosted: 11:16 - 27 Jul 2009    Post subject: Reply with quote
I've never had any problems with just 'not using it'. Bikes can quite happily sit for months with no ill effects whatsoever, in my opinion. Hell, the old CBR I got that had sat for 3+ years fired up on the fourth press or so.
The only thing to consider is if you've got an alarm fitted, you might want to stick the bike battery on charge now and then to stop it being slowly drained.
Besides, there are nice days in the winter too!
Jon-W
PostPosted: 11:18 - 27 Jul 2009    Post subject: Reply with quote
true, The reason I asked really is because the batterys in my ZZR tend to get un reliable if the bike is left un used (I guess its the same for any bike) and I dont really want to have to fork out for another next spring (just replaced it a couple of months ago)
PostPosted: 11:20 - 27 Jul 2009    Post subject: Reply with quote
I wouldn't call 4 months "looming" Smile
You could go through this but because it's Britain you've got to take what you can get, and ride all year.
Bendy
Mrs Sensible
PostPosted: 11:21 - 27 Jul 2009    Post subject: Reply with quote
If it's in the garage and you've got a plug, just get an Optimate on the battery to keep it happy.
Finglonga
PostPosted: 11:31 - 27 Jul 2009    Post subject: Re: Winter storage Reply with quote
Oh dear, bit of a defeatist! Ride it all year it wont dissolve, the best riding you can have it in bad weather. I dunno . . the youth of today! Mr. Green
Andy Sez....
F.Y.Y.F.F.
PostPosted: 11:37 - 27 Jul 2009    Post subject: Reply with quote
If you're doing it for the whole winter:
Wash the bike and make sure it is dry.
Brim the tank, add fuel stabiliser. Either drain the carbs or open the drains with the tap on "prime" to allow stabilised fuel to fill the float bowls. This stops the tank rusting and the fuel going stale.
Take the battery out of the bike, keep it inside.
Remove the sparkplugs, put a few drops of engine oil down the holes and turn the engine over a couple of times to spread it about, replace the plugs.
Make sure there is enought anti-freeze in the coolant.
Spray everything except the brake pads with a corrosion inhibitor like F365.
Park it somewhere dry, preferrably on a stand with both wheels propped off the ground.
When it comes to spring, charge and re-attach the battery, prime the carbs. Turn the engine over a bit on the starter with the plug caps off to get oil circulating to the top end.
Then fire it up. Once warm, do a mini service (change oil, check brake fluid, check tyre pressures, coolant levels etc. If it is latchy to start, put a few drops of petrol down the plug holes to help clear the oil that's been protecting the bores.
iooi
PostPosted: 18:01 - 27 Jul 2009    Post subject: Re: Winter storage Reply with quote
Jon-W wrote:
As the summer is looking pretty hopeless this year (constant rain) and the winter is looming.
When was the last time we actually had a winter.......
Bit like we never really get summers anymore, only spells of a few fine days. Karma
Stinkwheel, Has covered the rest.
Now stop being so soft and get riding your bike Thumbs Up
The last post was made 17 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 58.15 Kb
