honda nsr 125 f barrel
Burnzy1989
PostPosted: 15:36 - 27 Jul 2009    Post subject: honda nsr 125 f barrel Reply with quote
Hello to all,
I have had to buy a new barrel for my honda nsr 125 f and i found that my new barrel is a gilardoni 2 and my arigonall is a gilardoni 1 is there any difference between the two or is juust a up to date barrel ?.
tshort2007
PostPosted: 17:31 - 27 Jul 2009    Post subject: Reply with quote
There is a difference between the 2. From memory, they used different suppliers for the barrels, and all machined slightly differently on the bore (as in 1,000 of a inch), so pistons were matched to barrals by numbers 1-4. A Number 1 barral requires a number 1 piston etc. With so many aftermarket suppliers around, you will be hard pushed to find a perfect match, so i would just go for a standard setup with your barral and a std size piston (assuming your barral hasnt been re-bored)
Burnzy1989
PostPosted: 17:48 - 27 Jul 2009    Post subject: Reply with quote
Thanks,
So there is no diference in port timing in any way
tshort2007
PostPosted: 17:50 - 27 Jul 2009    Post subject: Reply with quote
not at all Smile just buy the correct dia piston, and stick it in. You may be a couple thou out, but if you run it in properly, you may only lose 2-3 psi of pressure. Not a major loss
Burnzy1989
PostPosted: 18:04 - 27 Jul 2009    Post subject: Reply with quote
Thanks
The last post was made 17 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 41.98 Kb
