Frames and Engines
POD
PostPosted: 19:07 - 27 Jul 2009    Post subject: Frames and Engines Reply with quote
OK so here goes, my better half has a Cooter Brown frame (stamped only with the manufacturer no) into which he is going to put a GSXR 1100 engine (super fast chop). If he gets the old frame no stamped onto the new frame thus keeping paperwork together is there a way of getting a different/new number for the old frame (sports) so it can be sold more easily?
PostPosted: 19:52 - 27 Jul 2009    Post subject: Reply with quote
Legitimatly not really.
He could buy another frame with a log book and use the identity of that.
The DVLA seem to be getting more dodgy on this at the moment with cars and will probably follow with bikes soon.
Legitimatly the custom frame with a doner engine should almost certainly land up on a Q plate. Way round this would be buying everything new for the custom frame (ie engine, suspension, etc).
POD
PostPosted: 19:54 - 27 Jul 2009    Post subject: Reply with quote
Expensive!!!!! However Ta for taking the time out to reply - there's so little info I can find
Thanks again
PostPosted: 20:18 - 27 Jul 2009    Post subject: Reply with quote
It is, but with much changed the view is it isn't the same bike.
Stamping up another frame with the original numbers is pretty dodgy as well.
sickpup
Old Timer
PostPosted: 20:41 - 27 Jul 2009    Post subject: Reply with quote
One of the latest DVLA scams is with old land rovers. Fit a new chassis and you have to have it inspected by them.
If you fit a new chassis and in the process change from leaf springs to coil springs they may well refuse to allow you to use the original registration mark.
tone
PostPosted: 22:00 - 27 Jul 2009    Post subject: Reply with quote
The way it used to work is you would stamp the new (chop) frame with the numbers from your old frame & destroy the old frame, not strictly legit i admit but as you legally own both frames nobody has been hurt & a blind eye was always turned (bit of a grey area)
whats happening now is some MOT testers are being bullied by vosa into reporting a "substantially altered vehicle" & refusing to mot it untill its passed an sva test, this is to combat ringing but is also picking up plenty of home grown specials
Its getting worse & more & more testers are being told how to recognise an altered frame (as if they didnt know already) the upshot of all this is you would need to prove the history of the parts on the bike through receipts etc + tot up a certain amount of points to keep your existing reg EG so many for stock engine, so many for stock chassis etc etc then submit the bike for an sva
The above bunch of bull is getting more common by the month & there is no grandfather rights EG "its been on the road like that for 15 years" is no defence + all current regs will apply EG noise regs lighting requirements, indicators etc etc
The only bright point on the horizon is that while an sva can be another expense if the bike is built right its not a great deal of problem to pass one
tone Neutral
Of all the things ive lost , i miss my mind the most
POD
PostPosted: 20:14 - 28 Jul 2009    Post subject: Reply with quote
Thank you all for the tips, they've been passed on and he's looking in the right (well better) places now
The last post was made 17 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 52.42 Kb
