Honda cg125 pitted forks
Rusty
PostPosted: 08:53 - 29 Jul 2009    Post subject: Honda cg125 pitted forks Reply with quote
Hi my son has a cg125 with pitted forks=mot fail
Its a 1989 drum brake cg125 br-j model.
Does anyone know which model fork tubes fit,i have had a quote from honda new £315 lol
I have seen fork tubes on fleebay but for the later disc model,and chinese copy models.
Greetz Rusty
TAX MY BRAIN
PostPosted: 09:11 - 29 Jul 2009    Post subject: Reply with quote
Quick fix.......
Fit gaiters to the forks ( to hide the forks tubes ) so long as they are not leaking they should pass an mot as the mot inspector is not aloud to remove the gaiter
Anyone care to confirm this as true ??
i also ride the local bike.............she's like a moped great fun to ride as long as your friends dont see you !!
Mudskipper
PostPosted: 11:10 - 29 Jul 2009    Post subject: Reply with quote
How pitted are they? If it's just surface pitting/rust it might be possible to sand it out (I did this with my GSXR forks).
Are the pits damaging the seals? I didn't think pitted forks alone constituted a fail - only leaking seals caused by the pits damaging them. What does the fail sheet say exactly?
Even badly pitted forks can be satisfactorily bodged using araldite as a filler. See stinkwheel's method below:
stinkwheel wrote:
Cut 'n paste from the last time I relayed this bodge Wink
You can do a bodge repair on pitted forks that is very effective although not all that aesthetic.
Firstly, clean all the rust off, down to bare metal, make sure you get rid of any flakes of chrome and scrape the rust out of the pits with a stanley knife blade.
Degrease the stanchions thoroughly using a solvent, you must completley remove all traces of oil clinging to them.
Now get some Araldite epoxy resin, it is improtant to use the original slow setting stuff (now marketed as precision?), NOT araldite rapide which absorbs water and swells over time.
Mix it up and skim over all the damaged parts of the fork stanchions, try to use as little as will fill the defects whilst still having it standing a little proud of the surface.
Leave to set for AT LEAST 24 hours.
Now using progressivley finer grades of wet and dry paper, polish down the araldite 'till it is perfectly smooth and level with the rest of the chrome surface, finish off with a cream polishing agent like autosol then a wax polish.
This works, I have done it many times. The critical parts are 1) How clean and grease free you get the surfaces. 2) The amount of elbow grease expended polishing.
Don't let them get in such a shit state again, fit gaiters if you can't be arsed cleaning and polishing them. Treat any new pits using the same technique as soon as they appear.
Rusty
PostPosted: 11:17 - 29 Jul 2009    Post subject: Reply with quote
Hi there are 3 pits that travel below seal,theses are not massive pits and seals last for a few months.
I have seen forks on fleebay cheap but most are from more modern disc models,if i can find a match this would be my preffered method.
If not then maybe i will try and fill them then cover with gaitors and try a different mot test centre
ty 4 feedback
Mudskipper
PostPosted: 11:30 - 29 Jul 2009    Post subject: Reply with quote
These are the ones I did (wet & dry only)
Mudskipper wrote:
Absolutely fine now after 7 months under gaiters.
PostPosted: 13:22 - 29 Jul 2009    Post subject: Reply with quote
Alternatively:
£72 for a pair here
Give them a clean up though, rust can look a lot worse than it is. As a general rule, if you can catch a pit with your fingernail, it could damage the seal and would benefit from treating.
The last post was made 17 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 53.25 Kb
