Tyre Thread - But I know Nout!
KevTM
PostPosted: 18:03 - 29 Jul 2009    Post subject: Tyre Thread - But I know Nout! Reply with quote
I'm pretty new to trail bikes etc and I feel like I know absolutely feck all about them and related consumables/products/etc. Laughing
I'll be buying new tyres for my '94 KLX650C1 in the next few days but I'm at a total loss as to what to get.
What's on it just now:
Front - Pirelli Scorpion 90/90-21 H (tubeless on a tubed rim?)
Rear - Metzeler Tourance 130/80-17H (tubeless on a tubed rim?)
How does a tubeless tyre on a tubed rim work, obviously it has a lip to bead onto as usual? Any benefits on tubeless over tubed or vice versa?
I'll mostly be on-road but want something that's "ok" for light off-road stuff, too - I was thinking:
Continental Escape's £115 total.
I'm assuming these are tubeless on a tubed rim type tyres and should be ok/fittable? Laughing (feel like a complete noob asking these questions)
Any other tyres I should be looking at?
Cheers Muchio.
Mystery
PostPosted: 20:13 - 29 Jul 2009    Post subject: Reply with quote
as far as i know bridgestone, dunlop and michelens make off road tires if you can afford them
ben_wheely
PostPosted: 12:00 - 30 Jul 2009    Post subject: Reply with quote
That was the most useless reply ever !
As to the OP. I run with a scorpion pro on the front and for off-roading it is brilliant, but its a little too aggressive for on-road. Why is it being run tubeless, when it is a tube tyre (even says on the sidewall) ?
I can't answer your question about how tubeless works. I think the only advantage of running with a tube is for off-roading - because it is very likely to get a puncture and instead of a new £40-£50 tyre, a £9-£10 tube can replace it, or a patch.
It really depends on what you are planning for the bike, what sort of off-roading and how much road work. But I would deffinatly stay away from a rear knobbly tyre on a KLX650.
Rides: '05 Yammy WR290-F
KevTM
PostPosted: 17:11 - 30 Jul 2009    Post subject: Reply with quote
The tyres have me confused at the minute. The Scorpion one (front) says on it "Tubeless - Tubeless tyre to fit tubed rim - Fit tube" (or along those lines) Laughing. The rear tyre just says tubeless on the side, so I'm assuming it is tubeless. I'll whip them off over the weekend and see if tubes are fitted.
As for pros and cons, I think you're right. Tubed for off-road as it's easier to whip the tyre off and do the repair to the tube (or swap it out for speed).
Had a wee shot on a KLR250 years ago on the road with knobblies, can be dodgy, so I'm definitely staying away from them for the time being Laughing
yeah weezy I think most manufacturers make off-road tyres, I think even Maxxi do them! Never been a fan of Continentals but I've heard good things about the Escapes so I'll give them a bash.
Mystery
PostPosted: 17:24 - 30 Jul 2009    Post subject: Reply with quote
ok, i don't know much about offroad either tbh but my mates use the 3 i said and have used em for years so they must be good, hope it works out for you though
PostPosted: 18:55 - 30 Jul 2009    Post subject: Re: Tyre Thread - But I know Nout! Reply with quote
Tubeless tyres on a tubed rim do not work. Well, not unless you also use a tube.
If you're going to be using the bike on road a lot, if at all possible I'd get a spare set of wheels. It's a big compromise between the two and you'll end up with faster wearing tyres that will do neither job well.
If not, basically look at the tread - the bigger the gaps, the better off-road and worse on-road.
I've got Metzeler Enduro 3 Saharas on my KTM690. They are fine on road, but off-road they are perhaps a bit 'concerning'. I was able to pretty much keep up on a green lane trip, but was sliding all over the place. A decent front on another trip with the same rear made a big difference; meant at least the front end went where I pointed, even if the rear was at a significantly different angle Smile.
The last post was made 17 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 50.13 Kb
