whats the difference between fuel injection, and a carb
RooRoo
Anal Intruder
PostPosted: 15:59 - 10 Jun 2004    Post subject: whats the difference between fuel injection, and a carb Reply with quote
just wondering, it seems newer bikes have fuel injection, im guessing my rs will have a carb though?
Mr Pants!
I Karma
PostPosted: 16:01 - 10 Jun 2004    Post subject: Reply with quote
Carb = https://auto.howstuffworks.com/question377.htm
Injection = https://auto.howstuffworks.com/fuel-injection.htm
Cool
Mr Pants! (Alex or Al)
Its better to burn out, than to fade away....
mr.z
PostPosted: 16:12 - 10 Jun 2004    Post subject: Reply with quote
Carbs - meer mortals can fix
Fi - You need a big pile of expensive diognostic equipment and a degree in neuclear physics
Generally i think fi is allot more efficient (and therefore powerfull) but can make powerdelivery in some cases very slightly delayed or jumpy..
Have a good read though those links there some really interesting things on there, epsecially the 2/4 stroke engine differences, brakes and clutches lots of stuff.. all very handy to know Thumbs Up
T.C
PostPosted: 16:26 - 10 Jun 2004    Post subject: Reply with quote
Fuel injected bikes pass the emission controls and tests a lot easier than carbs, and it also means more money to the dealers when it goes wrong as most of us don't have the equipment for doing the diagnostics, whereas with a set of carbs they are dead easy to rip apart and repair.
It is better to arrive 30 seconds late in this world, than 30 years early in the next
Dr Nick
PostPosted: 16:35 - 10 Jun 2004    Post subject: Reply with quote
It was on tele sometime, that Carbs actually deliver the mixture smoother to the engine than fi. Can't remember the whole thing but something about how the slide is the perfect shape or something. Confused
is that it
Visitor Q
$25 whore
PostPosted: 18:06 - 10 Jun 2004    Post subject: Reply with quote
Fancy fixing mine then? Wont idle worth shite, runs rich (i think) and stalls (with clutch in) when i stop suddenly.
Bring on the fuel injection Sad
PostPosted: 18:08 - 10 Jun 2004    Post subject: Reply with quote
Fuel injection is simpler than carbs really. Easier to design, but harder for someone to debug without the correct equipment.
No reason a fuel injected engine should not be as smooth as a carbed one. Trouble is that fuel injection is often added to get round emisions rules and that means pulling various tricks. For example on a closed throttle from higher revs a carb will still flow some fuel to the engine, and this will result in a smoother transition to an open throttle. However an injected engine will often cut the fuel totally while the throttle is closed, saving fuel and reducing emisions but making the power come in with a bit of a jerk when you open the throttle again.
mr.z
PostPosted: 18:14 - 10 Jun 2004    Post subject: Reply with quote
Get yourself a vacum guage, carb adjusting tool and a manual then do it yerself! its nowhere near as difficult as you'd think..
The problem with fi bikes/cars they rely on sensors, O2 sensors and all sorts, they are expensive, if any of them are broken you need the diognostic stuff to know which one is out. Sad
Ninja
Caption Abuser
PostPosted: 18:21 - 10 Jun 2004    Post subject: Reply with quote
Injection - being electronically controlled, can be mapped to give the optimum fuelling for any given load or engine speed range
Carbs - 'fixed' in their ability to deliver fuel for given rev ranges
James
4 wheels transport the Body ... 2 wheels transport the SOUL
mr.z
PostPosted: 18:34 - 10 Jun 2004    Post subject: Reply with quote
Ah, that explains allot, so haveing the ecu remaped would cure these "quirks" but perhaps have you failing an mot on emissions?
Claud 14.7 to 1
PostPosted: 18:49 - 10 Jun 2004    Post subject: Reply with quote
True. some aftermarket ecus you can switch between fuel maps, ie one for mot, one for road fuel, one for race fuel, all giving optimum fueling for each senario. ignition timing can also be "mapped" but thats another story.
i though fi rule, and carbs suck, but some points raised about carb are quite vaild.
still rather have fi though, cant get blocked,doesnt need adjustment, more accurate, etc etc etc.
PostPosted: 19:47 - 10 Jun 2004    Post subject: Reply with quote
Yes it can help, but the chances are that you will probably still pass an MOT in the UK (the UK MOT test uses a very simple and basic emisions test).
A fairly true saying about fuel systems used on the road is "Fuel injection gives an engine what it needs, carbs give it what it wants".
hugo-a-gogo
PostPosted: 22:25 - 10 Jun 2004    Post subject: Reply with quote
most of this applies to modern computer-controlled fuel injection, FI is just easier to make computer controlled
"There are some things nobody needs in this world, and a bright-red, hunch-back, warp-speed 900cc cafe racer is one of them - but I want one anyway, and on some days I actually believe I need one. That is why they are dangerous."
Hunter S Thompson
clicky 4 bikey
WildGoose
White Van Man
PostPosted: 23:06 - 10 Jun 2004    Post subject: Reply with quote
i like carbs, cos i understand the principle, and technically you can see the mechanics of whats happening
anything electronic that replaces anything mechanical is no friend of mine as far as mainteance goes
electronics makes me feel stupid if i'm honest, cos most of the time i find it a head fuck
mr jamez
PostPosted: 23:09 - 10 Jun 2004    Post subject: Reply with quote
I like tinkering and you can do that with carbs, the less electronics the better.
loply
PostPosted: 22:25 - 11 Jun 2004    Post subject: Reply with quote
Personally with a background in programming I find EFI completely natural, and I much prefer the option of being able to simply type in a number to set injection options for some particular RPM, rather then the dark art of messing with the various parts of carbs.
Tools for reprogramming EFI arent that much really - Not much more than the tools + books youll need to learn carbs. And you can change EFI at will, no need to buy new jets all the time.
Depends which way youre inclined though, I suppose.
The last post was made 22 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 93.66 Kb
