Author |
Robby |
 Robby Dirty Old Man
Back to top |
Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 18:00 - 10 Jun 2004 Post subject: |
Robby, from searching around the net for info on this emap, on garmins website they have the street pilot
https://www.garmin.com/products/spIII/
That looks pretty sweet, from memory, they are £899 retail but I'm 99% sure they've dropped to the £500/600 mark new (for the basic version of the colour model) thats from memory in Makro or something though so don't quote me on that, but I know for sure they are £500 brand new buy it nows on ebay ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
Back to top |
mr.z |
 mr.z World Chat Champion
 Posted: 18:04 - 10 Jun 2004 Post subject: |
The whole of the london area is about 25mb onthe metro guide set and about 8 on the roads and rec set.. you can the whole of the uk on my 1.5mb memory on the basic map (motorways and a roads)
It depends on what areas most of the peaks is about 200k or something, town areas of the same size use up considerably more...
The screen is probaly the same or biger than mine, you have to be carefull when you take a glance at it, in traffic is the best time (provided your not moveing obviously) just like glanceing at your speedo, if you need to do allot on it pullup, i do tend to push buttons on it while on the move but i know which ones and how many presses it needs by now
Quote: | If I was blindfolded, and taken to the middle of the country, somewhere I don't know, haven't a clue where I was, could I use the emap to easily find my way directly back to my house, just with that unit out in the middle of no where? |
As long as you have a strong signal (which is not a problem most of the time) then yes it will tell you where you are up to a few meters accuracy, same with any gps really... ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
Back to top |
Sparks! |
 Posted: 18:06 - 10 Jun 2004 Post subject: |
Quote: | The MetroGuide provides detail down to house numbers in streets in metropolitan areas and most towns, as well as local sites and facilities of interest. It also shows major roads and some rail lines. Only a sub-section of the UK can be stored in the memory card at a time - the greater London area occupies the whole 8MB, for example - but 16MB cards are also available, enabling you to store two or more regions in your eMap at a time.
In use, there is a Star Trek Tricorder novelty about using the eMap. It can tell you where and how high you are and be used to find and guide you to your destination by entering details like the name of a place, even the street address or conventional latitude and longitude co-ordinates. You can mark your own 'waypoints', create routes and copy this information to your PC for use with dozens of free, shareware and commercial applications. The eMap will work with applications like Microsoft's AutoRoute Express, for example. Many pocket computers will also work with the eMap, given a suitable cable and software. |
That seems to say that it will guide you i.e tell you to turn left/right etc etc and go here there etc based on your way points, it also says you can search by address etc, it says "copy to your pc" so i assume by the way it says that, you can do all the searching for addresses etc on the GPS unit itself.
Think if this stays under £100 , I'm going to go for it and see how I get on.
I presume this can definetly be plugged into a cigarette lighter thing that I can bodge onto my bikes electrics somehow  ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
Back to top |
mr.z |
Back to top |
Sparks! |
 Posted: 18:12 - 10 Jun 2004 Post subject: |
Just looked on that website with the mounting systems on, they do a yoke mount which fits the R1 and I'm 99% sure that will fit the R6 perfectly as the R6 also has a hole through the centre yoke.
The only thing I don't like with the eMap is that it is phone shaped and not a rectangle like the III plus... which will mean it won't mount quite so well. But should still fit fine onto the centre yoke and not be in the way or anything I hope. ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
Back to top |
tgabber |
 tgabber Crazy Courier
 Posted: 18:14 - 10 Jun 2004 Post subject: |
YamsR6 wrote: | Sorry for all the questions!!
I'm seriously tempted by that emap auction now
The price doesn't seem too bad and if you say I can put full detail maps for the south of england on there on a 32 mb card  then two cards and thats the whole of England in detail right? |
The catch here is that the Garmin memory cards are proprietry, expensive and quite difficult to get hold of... Easier just to swap the maps around on one card as needed
YamsR6 wrote: |
So I take it, that auction comes with software that I can sit here on my PC, program a few routes to specific post codes (on PC?) and then download to the unit itself and be able to pull them up when required.
It's not clear on that auction whether the software is included, but don't worry you'll get sorted...
YamsR6 wrote: |
Does it then show you on screen to turn left/right etc etc whilst moving? Or is it literally just an electronic map that you can look at and have it tell you where you are etc?
If you're following a route then the route is highlighted on the map and each time you get to a turning point you've marked on the route an 'Approaching turn' warning will pop up (although this can be quite easy to miss as it disappears fairly quickly). Most usefully I find though is that when route following you get an arrow showing you the direction you should be going in. If this arrow is not pointing approximately straight ahead then you know you've missed a turn!
YamsR6 wrote: |
It would be nice to have something that actually tells you where your going etc, the small emap one would be difficult to mount on my bike but it looks small and portable so can be used off the bike too and would make do until I require something better.
It sounds like it can do everything I need, if it can hold detail maps for the whole south of england, that should do me for what I'll ever need it for!!
The aim is to be able to program a route, from my house/location to another house/location easily and to be able to get there easily by it telling me where to go etc and also be a reference for planning ahead.
A computer software version where I could, for instance, plan rideouts then follow it on the GPS whilst out riding would be cool! (good way to share routes as well!!)
What is the screen like whilst riding though??
It looks small  will you see it whilst riding easily? if mounted on the dash.
Never mounted the Emap myself, just used it in the map pocket of my tankbag. I think it actually had a slightly clearer display than my current model. Other than using the navigation arrow, if I got a bit lost and wanted to study it in detail I would always pull over.
YamsR6 wrote: |
Cheers and sorry for the questions
Also, a way maybe for me to explain this a bit better is..
Does that make sense? lol  |
Well, unless the blindfold was taken off, you couldn't see the emap... But if it was (and you had a working set of batteries) then yes, you should have no problem finding your way home. Providing you know where 'home' is of course... ____________________ "It's all about dislocating expectation"
Kawasaki KMX125 -> Aprilia RS125 -> Kawasaki ZZR600 |
Back to top |
Sparks! |
 Posted: 18:19 - 10 Jun 2004 Post subject: |
I think this unit looks ideal.
I'm going to put a bid in if it's under £80ish.
If it doesn't come with the detailed software, is there any chance you could ermm, make me a "back up" copy?
I think I'm asking too much of the unit itself lol for what I want the street pilot seems to be the answer, but theres no way I'm spending that much money on something that's mainly only to find my way around easier. I'm not thick and can use a map etc and obviously happy to pull over, memorise some of the journey etc just by looking at the map itself rather than plotting routes.
Think it would be most handy when going on longer distance journeys to places I've never been before, and of course, pre-planning rideouts as I keep mentioning.
From a write up I've just read, the emap has the second largest display of the garmin range (below the street pilot) so it should be pretty decent once mounted up on the bike etc
just hope the bidding doesnt go crazy which it probably will Just have to keep looking for a bargain, I'm in no real rush. ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
Back to top |
mr.z |
Back to top |
Sparks! |
 Posted: 18:26 - 10 Jun 2004 Post subject: |
I may well ask for detailed wiring, but I'm 100% going to run the bike into work and get one of our sparkies to do it, as he's very very good with electronics etc in particular so shouldn't be a problem for him to wire it in properly for me I hope anyway :S
Now where'd I order those mounts from lol ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
Back to top |
mr.z |
 Posted: 18:35 - 10 Jun 2004 Post subject: |
I got my mounting brackets from aerostich in the usa, they turned up quite fast (about 4days!) have a look on the link above.. not sure what you'd need tho...
Wireing them is REALY easy, you just have to bear in mind if you have any loose + leads and they hit the frame then its two wheel fireball time, provided your carefull, dont have any tight wires liable to snap and crimp them into propper connectors useing correct ampage wire then theres not much you can get worng if they are in the right place  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
Back to top |
Sparks! |
 Posted: 21:47 - 10 Jun 2004 Post subject: |
outbid by £16
Will wait a while and try and find a bargain on there. Thanks for all advice so far  ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
Back to top |
monkeyman |
 monkeyman Scooby Slapper
 Posted: 03:45 - 11 Jun 2004 Post subject: |
Tarts  ____________________ Im not the best, but im in the top one
RM 250, Husky TE610, K1 GSXR 750 |
Back to top |
kevo |
 kevo Cop Seeking Missile
Back to top |
The last post was made 21 years, 71 days ago. Instead of replying here, would creating a new thread be more useful? |
