Is the brake disc warped?
kungfupoodle
PostPosted: 11:01 - 04 Aug 2009    Post subject: Is the brake disc warped? Reply with quote
Hello
My front brake is feeling a bit 'sticky' and needs a bit of TLC - hopefully just some cleaning and lubing in the right places.
I have also noticed that dragging the braking lightly the braking force varies as the wheel rolls around.
It doesn't seem to judder under hard braking though as a previous bike did with warped discs.
Any ideas?
Thanks
PostPosted: 11:13 - 04 Aug 2009    Post subject: Reply with quote
What kind of disk is it?
Floating disks can sometimes stick on the bobbins, as they get caked in brake dust. Brake cleaner and rotating the bobbins in place should hopefully free them off.
I have had some cast iron disks that developed a raised section where the pads rusted to the disk. Short of gettting them lightly skimmed I am not sure of a way round this.
kungfupoodle
PostPosted: 11:26 - 04 Aug 2009    Post subject: Reply with quote
Thanks. However, its a stainless non-floating disc on a CB500 Smile
Blue_SV650S
PostPosted: 11:30 - 04 Aug 2009    Post subject: Reply with quote
Warped discs are normally identified by a 'pulsing' at the leaver, can you feel any pulsing?
Also, to make sure, get the front elevated and spin the wheel, put a pencil from the fork pointing at and just touching the disc, you can then easily see if it is warped when the wheel spins - good luck Thumbs Up
kungfupoodle
PostPosted: 11:33 - 04 Aug 2009    Post subject: Reply with quote
Good plan. I will try and do this tonight and see how far it gets me.
kungfupoodle
PostPosted: 19:44 - 04 Aug 2009    Post subject: Reply with quote
Update:
I cleaned up the caliper. The pistons could be pushed back by finger pressure.
I did the pencil check and found the disc left the tip of the pencil for about half of its surface. Of course whether this is over the 0.1mm runout limit I can't say. It also drags against the caliper more in one part of the disc than the rest.
Went out for a test drive after cleaning the caliper and dragging the brake at low speed I could feel the weight coming on and off my arms as the braking force changed.
Still no judder in the lever though.
So.. definitely a warped disc? Very Happy
kungfupoodle
PostPosted: 20:23 - 10 Aug 2009    Post subject: Reply with quote
I don't like to leave a thread unresolved.
I changed the disc tonight (5 minute job) and now it no longer feels like I'm trying to stop on the worlds bumpiest road.. so that must have been it.
Its a revelation!
Odd that there was no pulsing from the lever.
PostPosted: 20:28 - 10 Aug 2009    Post subject: Reply with quote
Think it probably depends on how it is warped. Ie, if it is a gently warp over the whole circumference of the disk or a warp limited to a small part of the circumference.
The last post was made 16 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.65 - MySQL Queries: 13 - Page Size: 57.55 Kb
