Dyno costs and am I being fobbed off?
Pickledswede
PostPosted: 21:03 - 06 Aug 2009    Post subject: Dyno costs and am I being fobbed off? Reply with quote
Me and my brother put the restrictors in my CB500 the other day (they were included by the guy in the sale). So today I took it to Double Take Motorcycles in Southampton for a dyno test to check it was under 33bhp. Cost me £45 inc. VAT, is that an average-ish price for a dyno run?
My other worry is that the bike came out at 22bhp. The guy said he can file out the holes and dyno it again, and keep fiddling around with them until it gets to 33bhp ish for another £55, making £100 altogether. My question is, how likely is it that he did a dodgy run to get me to pay more to fix a problem that isn't there?
From what it looks like the top speed is ~87mph.
Bit of a noob on this topic but couldn't find any other dyno places near my area either so hard to get another opinion.
Any help greatly appreciated as currently I have it booked in for next Friday.
Cheers guys!
lllN30lll
PostPosted: 21:05 - 06 Aug 2009    Post subject: Reply with quote
most I've paid is £20.
Least I paid was a tenner.
and I paid £25 for an ECU remap, which is a steal.
Turbo R1
CRF450R
PostPosted: 21:08 - 06 Aug 2009    Post subject: Reply with quote
Possibly is a bit much for a straight power run. Depends if they were doing anything else at the same time (balancing carbs?).
When you fitted the restrictors were the holes in the washers in the centre or offset to one side? If offset to one side, how did you mount them on the bike?
A speed reading on a dyno is pretty meaningless. It is just a factor of the gearing. Gear up a 50 high enough and it would indicate a silly speed on a dyno if you had enough time.
carlperkins00...
PostPosted: 21:15 - 06 Aug 2009    Post subject: Reply with quote
yeah if the holes in the inlet blades (restrictor washers) was offset...
you need to insert the blades so that the hole is nearest to the bottom of the carbs.
if you put them in upside down it could mean less power.
i'd double check before you shell out £55 to have them altered.
if they were a cb500 kit that was bought then the holes should be the right size, you shouldnt file them out. in that case..
he is either ripping you off or theres something else wrong with the bike.
check the inlet blades first, then if they are correct find another dyno place.
hope this helps. Carl.
Handsome
PostPosted: 21:21 - 06 Aug 2009    Post subject: Reply with quote
I've just payed 30 of the Queens English whole round Pounds for a Dyno Session...
Pickledswede
PostPosted: 21:23 - 06 Aug 2009    Post subject: Reply with quote
That's probably it then, I put them in with the holes in the washers towards the top of the inlet rubbers. Would that make 10bhp of difference?
The guy did nothing else to the bike, so I guess I got ripped off. Spose there's nothing I can do about that now, live and learn.
I'll get the washers out and put them in properly, then maybe clean the chain, get new plugs and air filter and see if I can get the carbs balanced (it's a 15 year old bike and don't know when that was last done). My dad reckons those things might gain a few bhp.
After that I guess I'll look for another dyno place. I spent 2 hours looking and only found this one, anyone suggest any near Southampton?
I don't know where the kit came from, it was just thrown in with the bike, although the owner didn't seem like the kind of guy to buy some random washers and hope they worked!
Any other things I should be doing from here?
Thanks alot Smile
PostPosted: 21:30 - 06 Aug 2009    Post subject: Reply with quote
Probably make quite a bit of difference having the washers in upside down. And if not serviced for a bit then a good service will help.
carlperkins00...
PostPosted: 21:43 - 06 Aug 2009    Post subject: Reply with quote
yeah the holes towards the top will make quite a difference.
im not sure on the specifics but its something to do with the flow blah blah mumbo-jumbo (technical term).
turn them round and get it dyno'd again. should be fine Thumbs Up Very Happy
chances are if you paid the guy 55, he would have taken the bike apart, seen they were upside down, turned them round and then just gave it back. £55 for a 30 min job is a bit steep.
let us know how you get on? Very Happy
D O G
PostPosted: 22:17 - 06 Aug 2009    Post subject: Reply with quote
Before we all start lamping into Doubletake (not that we are, yet - hence the 'before'), I dealt with these guys a fair bit when I lived in Southampton, since they were local to work. Knew others who did the same, and never had a problem at all. They sorted out a very annoying problem on my SRAD and certainly didn't charge excessively.
They are always horrendously busy however, which may have a bearing on their price in this case.
Pickledswede
PostPosted: 12:53 - 07 Aug 2009    Post subject: Reply with quote
Yeah I thought the fact that it took me two hours to find one dyno place might suggest their prices would be a little higher!
Although I'm sure Carl is right, if I obviously didn't know the washers were the wrong way up he'd take my money and flip them leaving me none the wiser!
Other than that they've done nothing wrong really, I was just a little worried I might have been getting ripped off and this is my best place to come for advice!
I'll get the washers turned round sometime in the next few days and post here with the results!
Thanks again!
D O G
PostPosted: 12:58 - 07 Aug 2009    Post subject: Reply with quote
Rather than dynoing it after you flip the washers, just ride it - you should notice a 50% power increase. If it feels faster, then job is done, no point faffing on and spending more money just to get an extra couple of bhp.
PostPosted: 13:05 - 07 Aug 2009    Post subject: Reply with quote
A session!!!!!
It's £30 near me just for a power run.
Pickledswede
PostPosted: 17:11 - 07 Aug 2009    Post subject: Reply with quote
Yeah that's what I was planning to do, fucked if I'm spending another £30! Mr. Green
Handsome
PostPosted: 19:13 - 07 Aug 2009    Post subject: Reply with quote
Big_Ham wrote:
A session!!!!!
Yeah, Sorry, I meant one of them !... Embarassed
Alex_H
PostPosted: 19:19 - 07 Aug 2009    Post subject: Reply with quote
Its 30 bones where I go too, and the guy even tells you what you can do to your carbs to get a few more bhp! Even better was that he was right lol.
1998 r1, ccm 644 ds, 2000 r6 ghetto track bike
iooi
PostPosted: 20:36 - 07 Aug 2009    Post subject: Re: Dyno costs and am I being fobbed off? Reply with quote
You do of course realise that even a dyno printout will not stop the bike being taken to be tested if the police feel that way inclined if they stop you.....
Pickledswede
PostPosted: 23:06 - 07 Aug 2009    Post subject: Re: Dyno costs and am I being fobbed off? Reply with quote
Yep, the only reason I got the dyno printout was because I had no idea where the guy had the washers from and wanted to know I was restricted so in the event I do get tested by the police aat leastI know I am Smile
-EDIT-
Just checking, the inlet rubbers have a space on either side that the washer can go in, should I put them on the carbs side or the cylinder side of the rubbers?
PostPosted: 08:06 - 09 Aug 2009    Post subject: Reply with quote
I would put them cylinder-side, as far from the carbs as possible to minimise turbulation through the carburettor choke. It's just my opinion.
Charlie
PostPosted: 09:12 - 09 Aug 2009    Post subject: Reply with quote
£25 for me about 2 years ago, straight power run
I have since removed my restriction washers, mine where mounted very close to the carb. I'd listen to Geri though.
carlperkins00...
PostPosted: 13:17 - 09 Aug 2009    Post subject: Reply with quote
Mine were carb side on the hornet 600.
I dont suppose it would matter that much to be honest.
Pickledswede
PostPosted: 13:19 - 09 Aug 2009    Post subject: Reply with quote
Cool, I guess if they're carb side they're not gonna get sucked out, not likely that they would anyway, but this way they're being pulled against something rather than away from it! I'll get that done today!
Pickledswede
PostPosted: 13:12 - 15 Aug 2009    Post subject: Reply with quote
Right, all sorted! Took me about an hour, when it took ~5 hours with me and my brother doing it!
0-60 seems faster now, and I've had 90 out of it, but these were both down a hill, didn't seem to want to go anywhere after 90 so I'm inclined to think that's all it's got!
Thanks for the help guys!
The last post was made 17 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 115.67 Kb
