GS500 headlight pulsing
Squiffy_The_Wombat
PostPosted: 18:56 - 07 Aug 2009    Post subject: GS500 headlight pulsing Reply with quote
hey all,
have a GS500E and the front headlight seems to randomly sort of "pulse" now and then between high beam and dip (that or it just gets dimmer). Im not sure if its just because the inidi bulbs are blown on the left hand side or if the alternator is screwed (it does still get a bit brighter when rev'ed). Im not really fussed about it that badly as the bikes rarely used at night...just wondered if its a common GS fault or anything before i started taking things apart to check...
Cheers in advance
Toby
Squiffy_The_Wombat
Eagles may soar but wombats dont get sucked into jet engines
Gawain
PostPosted: 20:49 - 07 Aug 2009    Post subject: Reply with quote
I'd say you have some wires shorting out. Try turning the bars with the lights on to trigger it, also try moving wiring to source the fault.
Gazdaman
I did a trackday!!!
PostPosted: 18:47 - 09 Aug 2009    Post subject: Reply with quote
Mine did that.
Part of it was a problem in the charging system i.e it wasn't charging due to a massively corroded connector. Therefore I guess the light was running straight off the alternator? Or something along those lines.
Have a check see if it's charging ok, make sure the voltage is ok, suspect the reg/rec and connectors made of cheese.
My one was on the right side of the bike towards the front of the seat. I think it was a starter solonoid connector or similar. Just horribly corroded.
Gaz
D O G
PostPosted: 12:57 - 10 Aug 2009    Post subject: Reply with quote
Mine also does that.
Mine also has a horribly corroded starter soleniod.
Unfortunatly all of my tools are in a ISO container somewhere, so I can't do anything about it at the moment.
Squiffy_The_Wombat
PostPosted: 19:10 - 11 Aug 2009    Post subject: Reply with quote
Cheers for the info guys, i will get on the case with a multimeter once me buggered hands mended...will let ya know =)
Squiffy_The_Wombat
The last post was made 16 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.86 - MySQL Queries: 13 - Page Size: 43.75 Kb
