| tshort2007 |
 tshort2007 Scooby Slapper
 Posted: 18:56 - 07 Aug 2009 Post subject: Carburetter experts required!!! |
Afternoon all. Having some MAJOR issues still with poor idleing, to the point where the slide is adjusted around 1/3 up jut to idle at 1400 RPM. Acceleration is sluggish, and plugs foul every 800 miles. I have tried all kinds of adjustments on the float height, with no difference. The carb is factory set with the idle air screw, as the casting is blanked where the screw goes. After i eventualy get the bike started, after a run, if i take the carb off, there is fuel al inside the spigot joint to the engine. If i pull even slightly on the choke when idleing, the engine cuts out, which i belive indicates a ric circuit, along with the black, wet sooty plug.
I am stuck for ideas, and cant really afford to get a pro to look at it. Anybody got any suggestions?
Cheers all
Tom |
| Alex_H |
 Alex_H Borekit Bruiser
| P.addy |
 P.addy Red Rocket
| tshort2007 |
| Blue_SV650S |
 Posted: 19:50 - 07 Aug 2009 Post subject: |
Dude, is the main jet still 'in'?
Also take out the emulsion tube (the bit the main jet screws into) and check all the little holes are clear.
Also have you checked the needle jet is secure?
https://cv-performance.com/images/uploads/vortex_tube.jpg ____________________ The purpose of life is to fight maturity. |
| tshort2007 |
 Posted: 19:58 - 07 Aug 2009 Post subject: |
The needle is secure, and the needle jet is secure (te main jet clamps it in) the holes are all clear in both the brass jets. 3 observations -
1, I cant see any holes where the needle jet (emulsion tube) fits into the carb body inside the tube. Should there be any? (apart from the needle end and the main jet end, obviously!)
2, the needle is sloppy in the needle jet. how 'snug' shoud this be, and will it affect the idle?
3, there s a small jet i belive runs off the choke. this is split and damaged. will this make any difference if the choke ciruit is closed off |
| tshort2007 |
| kungfupoodle |
 kungfupoodle Renault 5 Driver
| Blue_SV650S |
| tshort2007 |
| Blue_SV650S |
| tshort2007 |
| Blue_SV650S |
 Posted: 09:43 - 08 Aug 2009 Post subject: |
| tshort2007 |
 Posted: 10:20 - 08 Aug 2009 Post subject: |
have blown through the 2 holes in the front of the carb on the air intake side, and both blow through into the emultion tube. by the holes in the bottom of the crb, i assume you mean the holes to the side of the top of the emustion tube, therse are also clear. how many holes are there inside the emulion tube (the casting, not the brass) from the air intake side?
i think poking with bristles from a brusare in order!!!
PS, will pop pics on later today, bike is at work at the moment. Bloody shame its runnin crap, as its a pefect biking day today  |
| tshort2007 |
 Posted: 10:46 - 08 Aug 2009 Post subject: |
images below ( i hope ) |
| tshort2007 |
 Posted: 11:19 - 08 Aug 2009 Post subject: |
UPDATE - STILL NO JOY
Stripped the carb compleatly, scubbed all the crevicis wih cotton wool and carb cleaner. rebuilt, and nothin
I have shown below a mod to the above image showing my idle circuit. the main feed in comes direct from the air jet in the intake of the carb. i assume it atomises as the emultion tube, so why is it still putting too much fuel in?
AAAAAAARRRRRRRRRRRGGGGGGGGGGGHHHHHHHHH |
| garyd |
 garyd Brolly Dolly
 Posted: 13:27 - 08 Aug 2009 Post subject: |
Use your mates carb and ride the bike,if its now ok stop messing about and get a new carb.Then play about with that old one at your leisure  ____________________ CRF230 all you need |
| tshort2007 |
 Posted: 16:23 - 08 Aug 2009 Post subject: |
Read my above post - funds are VERY low!! mates carb works fine, had it on for 3 days, cold starts, hot starts, wet starts, all fine!
SO i know its a carb issue, and cant afford the 110 for a new one  |
| tshort2007 |
| baldy |
 baldy World Chat Champion
| tshort2007 |
| Blue_SV650S |
| tshort2007 |
 Posted: 13:27 - 09 Aug 2009 Post subject: |
| Quote: | So you have air-lined every jet and orifice? |
Yes, at least times with carb cleaner and 120psi air line
| Quote: | Is the seal round the slider top cap good? |
didnknow there was one
erm, no. its split, held together wih parcel tape and very perished
is this sigificant?
| Quote: | Are there any hairline cracks in the carb? |
No. WD all round, no bubbles or cracks
| Quote: | Put the float height back to stock. |
Done - nothing
| Quote: | At the end of the day, if it won't idle, then it has to be the slow circuit we are looking at. By jamming the throttle 1/3 open, you are running the main circuit (controlled by the needle at this point) suggesting no fuel or too much fuel is flowing through the slow system. |
fully agree, i belive its rich, but the bike will not start without the slide so far up, so i can only guess |
| tshort2007 |
| Blue_SV650S |
The last post was made 16 years, 283 days ago. Instead of replying here, would creating a new thread be more useful? |
