1997 ER5, poor running, failing to start, black smoke etc
ncrn
PostPosted: 18:57 - 09 Aug 2009    Post subject: 1997 ER5, poor running, failing to start, black smoke etc Reply with quote
I'm a bit stuck so I'm hoping you guys can help me out.
On friday my bike started up fine after work, I made it about 5 miles and I hit the reserve line, so I flicked it over and kept going. After about a minute or two the bike started to bog down a little bit like it had hit the reserve line again, it was fine again shortly after. So I pulled over and got some fuel.
Then the bike wouldn't start, it would turn over fine but it wouldn't fire. I left it for a few minutes to cool off. I got it to start after a while, but a lot of black smoke came out the back of the exhaust and it wouldn't idle properly I had to keep revving it to keep it going. Fuel started pissing out of the air box so I stopped it again. I eventually managed to limp it the rest of the journey home.
Initially I felt I may have a blocked carb or something, so I took the carbs out stripped out the floats and the valves cleaned them all up, re assembled the carbs and put the bike back together.
It still won't start however the starter stopped turning which was caused by a flat battery so I am charging it at the moment. However I'm not convinced I've found the problem.
I can't find the spark plug spanner for my bike so I'm unable to check the plugs till I can get to town tomorrow.
Sorry for the essay but does anyone have any idea what the problem might be?
MaybeGuy
PostPosted: 19:05 - 09 Aug 2009    Post subject: Reply with quote
all i can think of is the following:
your fuel tank had loads of shit floating around the bottom of it, and you have a perished fuel filter.
as soon as you switched to reserve, all the shit went into your carb, cacking up your float valve and causing a leak.
solution:
clean out your carbs and tank, and get an inline fuel filter.
ncrn
PostPosted: 19:14 - 09 Aug 2009    Post subject: Reply with quote
I cleaned out the carbs though and they weren't too dirty, it wasn't perfect but it wasn't horrible. Will the fuel filter be in the fuel tap or will it be part of the fuel tank?
MaybeGuy
PostPosted: 19:15 - 09 Aug 2009    Post subject: Reply with quote
not sure as ive never owned one. usually on bikes with a reserve tap its on the inside of the tank, attached to the fuel tap.
did you take out the float and check the valve and jets?
ncrn
PostPosted: 19:17 - 09 Aug 2009    Post subject: Reply with quote
Cool, cheers I'll take a look and see.
ncrn
PostPosted: 19:41 - 09 Aug 2009    Post subject: Reply with quote
I've been out and tried firing it up with the battery charged. It still isn't going, its cranking over fine but its not going. If I try twisting the throttle a bit as I start it the sound changes a bit but it doesn't sound like its firing. Looks like I won't be able to get to work tomorrow so I guess I'll try get hold of a spark plug spanner and get them out to see if they are sparking or not.
tshort2007
PostPosted: 20:18 - 09 Aug 2009    Post subject: Reply with quote
black smoke is oil. Head gasket or rings i'm afraid. run a compression test, and check for white cack in your water
ncrn
PostPosted: 20:21 - 09 Aug 2009    Post subject: Reply with quote
I always thought black smoke was petrol, blue smoke was oil and white smoke was water?
MaybeGuy
fuelling can also cause black smoke.
ncrn
PostPosted: 21:12 - 09 Aug 2009    Post subject: Reply with quote
That sounds about right, there were some small dirt deposits in the carb so I guess that could have been it.
I can't get the plugs out with the spanners I have so I'm going to get a new set tomorrow, I might have to do some angle grinding but hopefully I can get them out and look. I will post back when I know what has happened.
Stelmer
PostPosted: 00:25 - 10 Aug 2009    Post subject: Reply with quote
Check the oil for petrol contamination too.
On my old ER5 I had a bit of rust jammed inside the needle valve. Was only a tiny bit but as the fuel tap stayed on when the engine was off, it kept filling up the carb and then into the cylinder.
It has a habbit of seeping into the oil. You will smell petrol in the oil if it's contaminated. However, mine was an extreme case as it was stood for a week like this till I fixed it.
ncrn
PostPosted: 14:23 - 10 Aug 2009    Post subject: Reply with quote
I've got the plugs out, they were definitely fouled. I managed to clean them up but they aren't perfect still. However there is a white spark if I hold the plug up against the frame. I'm not sure they might need replacing still but there is definitely a spark on each plug.
The bike won't start still however, I'm really not sure what is wrong now, I'm sure there is fuel getting through but how can I check to be sure? I am really in need of getting this bike work before the start of sept so if anyone has any ideas that'd be great Very Happy.
nowhere.elysium
The Pork Lord
PostPosted: 19:07 - 10 Aug 2009    Post subject: Reply with quote
This sounds identical to what was happening with my Bandit. I'd say that it *could* be to do with it not getting enough air, since it's burning too much fuel, and has fouled plugs.
The answer in my case was to take the airbox off, and once I'd made sure there wasn't a huge amount of crap being blown about, I just kept trying to start the bike, until it finally fired up.
It turned out that the airbox was gummed up to buggery, so I've put some temporary K&N knockoffs on, and it's working again.
No guarantees that it'll solve your problem, but it might be worth looking at the airbox again. Try disconnecting it, hooking the battery up to a jump starter, and just keep your thumb on the starter button for a minute or two. Sounds horrible, but it worked for me.
ncrn
PostPosted: 19:14 - 11 Aug 2009    Post subject: Reply with quote
I got hold of some new spark plugs, should I still try heating them before I put them in?
Also I will pull the air filter out the box is clear but the filter is shagged I think.
ncrn
PostPosted: 21:33 - 11 Aug 2009    Post subject: Reply with quote
The bike lives Very Happy its a bit smokey on the exhaust but I think it might just need a decent run in again, I'll keep an eye on it.
Also I found out why it got clogged so easily, my fuel filter isn't there at all, fuck knows why but they are just missing Shocked.
Stelmer
PostPosted: 22:18 - 11 Aug 2009    Post subject: Reply with quote
I'm sure the filter is built into the fuel tap on them bikes. Was on mine as I dismantled it to repair the vaccum side of it.
ncrn
PostPosted: 16:29 - 12 Aug 2009    Post subject: Reply with quote
When I took mine apart last I don't remember there being one, I have an A1 model so they may have changed it? Either way I have a new inline filter so I will be fitting that.
The last post was made 16 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 102.77 Kb
