Why aren't drive belts used more often?
PostPosted: 07:40 - 10 Aug 2009    Post subject: Why aren't drive belts used more often? Reply with quote
Other than Harley/Buell and mopeds not other bikes use drive belts to me they seem like a much better way of putting down the power.
I imagine they are lighter, cleaner, require less maintainence and are easier to change, so why aren't they used more often?
Ariel Badger
PostPosted: 07:53 - 10 Aug 2009    Post subject: Reply with quote
They are less mechanically efficient at delivering power to the back wheel than a chain.
BanditsHigh
Worse than a woman
PostPosted: 08:02 - 10 Aug 2009    Post subject: Reply with quote
^^^ Are they ... and here's me thinking that the order of most efficient power transmission (i.e. least amount of power loss) was belt > chain > shaft!!
The main reason I'd say they are not used more often is down to cost ... a chain and sprockets are cheaper to produce than the equivalent belt and pulleys.
All the best ... Barry
PostPosted: 08:15 - 10 Aug 2009    Post subject: Reply with quote
I would have thought then certain expensive bikes would have belts if cost was the only issue. If they are better that c&s why do race bikes/Ducati/MV etc. not use them.
elgard
PostPosted: 08:19 - 10 Aug 2009    Post subject: Reply with quote
I had a Kwak EN450ltd that was belt drive.
I did like it,Hardly any maintenace but when it went on me i had to buy a genuine belt and that was £230 Shocked. I just couldn't find anybody that did aftermarket belts.But that was in the days before the internet.
Timmeh
PostPosted: 09:33 - 10 Aug 2009    Post subject: Reply with quote
There's no way I'd trust an overgrown fanbelt to deliver 150bhp to my back wheel, I think most jap engineers feel the same.
D O G
PostPosted: 09:51 - 10 Aug 2009    Post subject: Reply with quote
BMW F800S, ST and R use belt drive.
Which is one of the reasons I like them so much.
extreme3d
PostPosted: 10:53 - 10 Aug 2009    Post subject: Reply with quote
Belts are more efficient than chains as there is considerably less free play. This also has the added benefit of reducing the lag in throttle response. It would be the logical choice really, but I suspect the reason for the choice of chains on the majority of sports bikes is the image that is associated with belts from their use on cruisers.
It takes considerable bravery from one of the big 4 to deviate from the norm when the other 3 are pushing forward three almost identical models.
PostPosted: 11:03 - 10 Aug 2009    Post subject: Reply with quote
You can repair a chain at the roadside with a split link. With a belt, you need a new one.
AngelGrinder
PostPosted: 11:07 - 10 Aug 2009    Post subject: Reply with quote
extreme3d wrote:
quote]
If they are more efficient....why do racers not use them, why don't WSB, MotoGP etc use them?
The bikes are all built for function, with looks coming secondly generally, so why aren't they belt drive?
Interesting question if they are more efficient. Although, the sprocket (if thats what they are called) for a belt must be wider than a chain equivalent, so might be heavier?
Noxious89123
PostPosted: 11:35 - 10 Aug 2009    Post subject: Reply with quote
Because having a huge pulley on the back;
Exhibit A
https://www.motorcycledaily.com/050808middle2.jpg
Means extra unsprung weight. Every gram counts remember! Mr. Green
Charlie
PostPosted: 11:39 - 10 Aug 2009    Post subject: Reply with quote
I think a lot of the bike manufactures (mainly Japanese ones) have invested lots of money into chain technology and don't want to invest money again when their view is that chain drive is totally adequate.
I think it is a good idea having belt drives, the no maintenance bit being the main reason.
extreme3d
PostPosted: 12:05 - 10 Aug 2009    Post subject: Reply with quote
I don't think weight is so much of an issue as it would be easy to make a strong lightwieght pulley. Besides the increase in weight would most likely be countered by the increase in drive efficiency. You are right though regarding the size, it's big in both width and diameter so as to increase the surface area and number of 'teeth' in contact between belt and pulley. Otherwise it is possible for the belt to slip as it jumps over teeth.
It is probable therefore that in the race environment chains are deemed overall more reliable. Naturally what happens on the track is mirrored on the road.
PostPosted: 12:20 - 10 Aug 2009    Post subject: Reply with quote
A new, well adjusted, well lubed roller chain (like they use in racing) is more efficient. How many people can hold their hand up and say their chain is like that all the time?
Belts need minimal maintainance, they need adjusting very infrequently (like, when you remove the wheel to change the tyre), don't need oiling and last around three times as long as a chain.
Last chain ans sprocket set I got was £115. So I'd have spent £345 on chain and sprockets, plus the time taken to fit them, plus the time pissing round cleaning and lubing them for every belt that needs replacing.
The girlfriend has one on her GPz305 and it's superb, I never have to touch it. It does squeak slightly but that's due to the early pulley design.
The reason they don't use belts is because bikers are set in their ways and fear change (as demonstrated in this thread). They therefore don't fit them because people won't buy them.
Anyone I know who has actually owned a belt drive bike thinks they are great.
neil.
PostPosted: 13:12 - 10 Aug 2009    Post subject: Reply with quote
Can't do the old 'stretch a pair of tights round and knot them up' trick then? Twisted Evil
doggone
PostPosted: 13:22 - 10 Aug 2009    Post subject: Reply with quote
They won't normally fail completely, you'll get a degree of shredding first which yo should spot.
The power handling argument is spurious too - unless the belt used is built to cost instead of strength.
Combined harvesters run on drive belts and they weigh many tons and engine considerably more powerful than a motorbike.
LordShaftesbu...
PostPosted: 13:52 - 10 Aug 2009    Post subject: Reply with quote
While I can't argue with this as a general truth, in the case of chains vs. belts weren't the earliest bikes belt driven? So if bikers were truly conservative we'd still all be using belts.
neil.
PostPosted: 14:09 - 10 Aug 2009    Post subject: Reply with quote
Leather belts were first used and they used to slip a lot. There wasn't any other material back then that could do the job better. Thumbs Up
Reppyboyo
PostPosted: 14:16 - 10 Aug 2009    Post subject: Reply with quote
I would love a belt drive on my Speed Triple.
Think replacing the belt would mean taking the swing arm off though which would be a bitch.
s44678
Guest
PostPosted: 14:30 - 10 Aug 2009    Post subject: Reply with quote
Surely it's down to chains being more suitable for racing:
You can mess with sprocket sizes, adjust wheelbase inside the paddock and then easily make up a chain to fit in minutes.
With a belt, it has to be moulded to a specific size using serious equipment. Basically it's a lot less flexible (pardon the pun).
Fine for the road where your bike setup is pretty consistent, but not very good for a racing team I wouldn't imagine.
And thus, like lots of other things (helmets, fairings, paint schemes) we like our bikes to look like race bikes whether the technology has any real benefit on the road or not.
extreme3d
PostPosted: 14:51 - 10 Aug 2009    Post subject: Reply with quote
Since wheel base changes are only going to be small (otherwise the entire swingarm would need to be swapped negating the 'quick' adjustment) I can't see how adjusting the wheelbase slightly would need a new belt. It would be easy to design the tensioner pulley to be adjustable to cope with the difference in tension if the wheel was moved.
PostPosted: 19:03 - 10 Aug 2009    Post subject: Reply with quote
The reputation of the belt drive systems used on some 1980s Kawasakis was that they lasted a bit longer than chains of the time (but within the margins for a well looked after chain, certainly one with a properly set up scot oiler).
They are efficient (a good condition chain is better) and need little adjustment
Down side is that the belts tend to fail will very little warning. They are expensive (although that might change if they were more commonly used so more independent suppliers), require the rear suspension stripping to replace (which is a real pain if you want to play with gearing) and not resistant to damage.
From memory there was someone racing a 250 GP bike in the late 1980s using belt drive for a while.
Ariel Badger
PostPosted: 19:15 - 10 Aug 2009    Post subject: Reply with quote
As I said in the second post they are less efficient than a chain for delivering power to the wheel.
PostPosted: 19:19 - 10 Aug 2009    Post subject: Reply with quote
Trouble is that as a chain wears and it stretches its efficiency gets worse.
AngelGrinder
PostPosted: 19:32 - 10 Aug 2009    Post subject: Reply with quote
So, basically.
Chain is good for racing because it is better, as they only ever use brand new ones. Chain is better because you can change it alot quicker.
Chain on road is good because racers have it and because that's where the technology is, so it's pointless for the manufacturers to bother doing stuff that would be better for the road?
The last post was made 17 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 132.76 Kb
