Triumph S4 Gearing Problem
leeclissett
PostPosted: 09:08 - 10 Aug 2009    Post subject: Triumph S4 Gearing Problem Reply with quote
Hi guys
Picked up an '05 Triumph Speed Four at the start of the year, it's been garaged since then with the occasional spin to keep her healthy. Finally passed my test the other week so got her out on the road proper.
This weekend there were more than a couple of times where I couldn't get first gear. Couple of times I rocked the bike backwards a few inches and it seemed to jump into first. Bike was given a full service before I picked it up in January but has probably only done 20 miles before this weekend.
I'm by no means a mechanic but the clutch doesn't seem to be biting too early, cable seems fine and the gear change rod and arm seem in good nick. Am I missing something simple or do I need to run it to the dealers?
extreme3d
PostPosted: 09:11 - 10 Aug 2009    Post subject: Reply with quote
Has the oil been changed? If not thats the first thing I would try before taking anything apart.
PostPosted: 09:20 - 10 Aug 2009    Post subject: Reply with quote
Chain at the corrent tension and well lubed?
Are the linkages from the left rear set to the actual bit where it goes into the engine all well greased?
Those are both simple things that can cause your gearbox to seem huffy.
The last post was made 16 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 35.4 Kb
