Removing Rounded Torx Bolt
Chriss
PostPosted: 11:07 - 11 Aug 2009    Post subject: Removing Rounded Torx Bolt Reply with quote
Hi!
I'm trying to change the brake discs on my car, and typically one of the torx bolts has rounded.
This bolt is hidden by the disc, the 'wrong' side, so access is extremely limited, as in, I can't even get an impact driver to it.
Short of just blowing the fucking car up and claiming on the insurance, how can I fix it?
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
Gunny
PostPosted: 11:24 - 11 Aug 2009    Post subject: Reply with quote
Whats the bolt holding on?The disc?Or the caliper.
Any chance of a photo
WWW.SCOTTISHBIKERS.CO.UK
T1z3R
cut a slot in it for a plain screwdriver bit?
duck my sick!
Chriss
PostPosted: 11:47 - 11 Aug 2009    Post subject: Reply with quote
The caliper carrier. It's what's stopping the disc from coming out.
I don't think there enough room for any cutting equipment.
No photo, too bright outside, and too dark inside. You just get a load of black on white. Thumbs Down
Chriss
PostPosted: 11:55 - 11 Aug 2009    Post subject: Reply with quote
Got a photo.
It's the blur on the bottom.
https://farm4.static.flickr.com/3499/3810590365_2732ee02a3.jpg
Hopefully it kinda shows that I'm limited for room. Thumbs Down
PostPosted: 12:00 - 11 Aug 2009    Post subject: Reply with quote
use a dremel to cut a slot in it then use a screwdriver.
extreme3d
PostPosted: 12:58 - 11 Aug 2009    Post subject: Reply with quote
In addition to the advice above regarding cutting a slot, might be worth spraying some plus-gas onto the bolt in an effort to counter what caused to to seize in the first place.
A trick that can work sometimes is to tighten the bolt a fraction before unscrewing. This can help to break the bond.
arry
PostPosted: 13:12 - 11 Aug 2009    Post subject: Reply with quote
S'what I'd do, also - undo the bottom carrier bolt and wiggle the carrier up and down a bit to get the bolt freer before trying to undo
Xenocide
PostPosted: 13:16 - 11 Aug 2009    Post subject: Reply with quote
Go and get some proper bolts from your local bolt factor before you put them back on!
KTM LC4 400 | Honda VTR1000
PostPosted: 13:17 - 11 Aug 2009    Post subject: Reply with quote
You'll never turn that with a screwdriver. Wiggling the carrier up and down to help break the bond is a good idea though.
Xenocide
PostPosted: 13:19 - 11 Aug 2009    Post subject: Reply with quote
You could always try smashing a socket over the top of it (a small one) and twisting it off.
Gunny
PostPosted: 14:04 - 11 Aug 2009    Post subject: Reply with quote
If there was room to swing a hammer and either try to smash a socket over the top or hammer in the next size up bit.
Had something similar and we air chiseled the head of the bolt
tshort2007
PostPosted: 16:38 - 11 Aug 2009    Post subject: Reply with quote
that bolt will have loads of loctite on it. heat it up good and proper with a blowtoarch, (keep the caliper out the way!)
Stalk
PostPosted: 20:54 - 11 Aug 2009    Post subject: Reply with quote
From what I can see in the picture..
Cut the head off the bolt with an anglegrinder, withdeaw the disk and caliper carrier together, put what is left of bolt in vise and unscrew carrier. Get genuine replacement bolts, they are important.
Hope that this helps,
Stalk
arry
PostPosted: 21:28 - 11 Aug 2009    Post subject: Reply with quote
I'm thinking that access to get a grinder in there isn't an option without removing the whole hub assembly, which seems very much "next step" if the all else bodger choices fail
tshort2007
PostPosted: 21:35 - 11 Aug 2009    Post subject: Reply with quote
Did my brakes on my vectra couple weeks ago. Het the bolts (top and bottom) up from the front end as much as you dare. Tap the bolts a couple times with a hammer, this will cook the loctite and make it brittle. Undo the good bolt, then do as Arry suggested, and move the carrier to unscrew the damaged bolt a little to break the seal. if you still cant undo the bolt, i suggest drilling and tapping a hole carefully in the front end of the bolt at least 15mm deep, then screw in a hex head stainless bolt and tighten. this will eventualy bite, then unscrew the main bolt!
Chriss
PostPosted: 22:07 - 11 Aug 2009    Post subject: Reply with quote
Bolts off, Babykat from here came round and fixed it (what a hero!)
Hitting the carrier and wiggling it broke the seal, which freed it up. He then unscrewed it by hand. Embarassed
Finglonga
PostPosted: 22:38 - 11 Aug 2009    Post subject: Reply with quote
Calliper carrier bolts need to be high tensile, so make sure you get the correct ones.
Doubt it very much. No need to thread lock them there.
Andy Sez....
F.Y.Y.F.F.
The last post was made 16 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 96.69 Kb
