Brake Master Cylinder Lesson Needed
Chriss
PostPosted: 15:43 - 12 Aug 2009    Post subject: Brake Master Cylinder Lesson Needed Reply with quote
Hi,
What's the difference between a radial master cylinder, and a... normal one? Secondly, when it comes to sizes, what does 16x18 etc mean? How would you choose the best one to suit your bike? Or is it just down to which ones fit the bike?
Massive thanks in advance. Thumbs Up
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
PostPosted: 16:38 - 12 Aug 2009    Post subject: Reply with quote
A normal M/C is mounted parallel to the lever, whereas a radial one is mounted 90 degrees to it.
16 x 18 or whatever is the ratio of the M/C. So how much it increases the force you put in at the lever end.
Some increase the force loads, but have very little feel, whereas other increase the force less but have more feel.
At least I think that's right.....
Radial:
https://www.superbiketoystore.com/sport/images/uploads/brembo-clt-mc.gif
Normal:
https://www.randakks.com/Nissin%20Master.jpg
See the difference?
I know AP Racing do an M/C with adjustable ratio, unsure how much it is though.
Chriss
PostPosted: 16:47 - 12 Aug 2009    Post subject: Reply with quote
General rule of thumb = As power increases, feel decreases?
Frost
PostPosted: 16:56 - 12 Aug 2009    Post subject: Reply with quote
To some extent yes.
Often there are things that reduce both however, things like air in the brake lines, boiling fluid, weak hoses etc.
MaybeGuy
PostPosted: 17:37 - 12 Aug 2009    Post subject: Reply with quote
i always thought the 16x18 was bore size, not power ratio. and if 16:18 was the ratio, the bike wouldnt stop very well at all unless you had superman grip!
length x width.
some of them are different sizes for twin or single calipers as more fluid is required to move twins.
same with 4 or 6 pot calipers.
i THINK of the top of my head, 16x18 is best suited for 4 pot twin calipers. or so i read somewhere.
PostPosted: 17:44 - 12 Aug 2009    Post subject: Reply with quote
The numbers on a radial master cylinder refer to the 2 different things that affect the ratios. One is the master cylinder bore (so affects the hydraulic ratio between the master cylinder and the caliper pistons), the other is the distance from the lever pivot point to where it presses on the master cylinder (well, simplified it is).
In a perfect system (ie, no air, etc), more lever movement will give you the same braking force for less lever pressure. Similarly less movement will give you the same power for more lever pressure. More pressure tends to mean less feel.
Not sure there is any real basic difference in radial and non radial master cylinders, just that radial ones tend to use far larger pistons and a far smaller distances from the pivot point to the piston. Suspect that they just have a better choice of these ratios.
Fisty
PostPosted: 18:48 - 12 Aug 2009    Post subject: Reply with quote
Big_Ham wrote:
some stuff
Radial:
sorry thats a clutch master cylinder Razz
Fatter and faster than Fret
PostPosted: 19:34 - 12 Aug 2009    Post subject: Reply with quote
Pedant. Laughing
BanditsHigh
Worse than a woman
PostPosted: 06:01 - 13 Aug 2009    Post subject: Reply with quote
I agree that the first number is the size of the bore, but surely the second number relates to the stroke of the piston in the bore, this then gives the total amount of displacement available for moving caliper pistons!!
You need a master cylinder which pumps the correct amount of fluid for the caliper used, i.e. a six piston caliper will need more fluid displaced than a four piston caliper to make the pistons move the same distance.
All the best ... Barry
PostPosted: 08:26 - 13 Aug 2009    Post subject: Reply with quote
The stroke is pretty much determined by the size of the caliper pistons. The ultimate stroke should (hopefully) never be an issue.
This might give you a few details:-
https://cyclebrakes.com/html/brembo_cylinders.html
Agree that the amount of fluid pumped is important. Put a master cylinder designed for a pair of 6 piston calipers onto a bike with a small single piston caliper and there would be negligable lever movement and stuff all feel.
The last post was made 17 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 69.03 Kb
