RS125 Question
PostPosted: 21:25 - 11 Jun 2004    Post subject: RS125 Question Reply with quote
Right, i got my RS 2000 model on tuesday. The guys at the dealership advised me to get around 200 mid rev miles on it to let it run in. So i've done exactly what they said.
Heres the problem.
No matter what i do, it wont go above 60mph. Jonny took a look at the engine the other day and he said that the power valve is all there and connected up. But the bike still wont rev over more than about 8000-9000 rpm.
I'm guessing that a blanking plate has been fixed in place of the normal power valve.
Its really annoying me now as i hate not being able to use the A19 for college, whereas with the NS125R i could get to a good 85mph and i was there in no time at all.
If anyone has any ideas, i'd appreciate hearing them Thumbs Up
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
Scooby
Scrappy Doo
PostPosted: 22:11 - 11 Jun 2004    Post subject: Reply with quote
Almost sounds like an electrical restriction. Wouldn't be able to tell without seeing the bike though. Probably best off taking it back to the shop where you got it from and getting them to sort it out as a full power bike for you.
RooRoo
Anal Intruder
PostPosted: 01:03 - 12 Jun 2004    Post subject: Reply with quote
sounds annoying, electrical restriction on an RS is odd though isnt it?
what does the RS redline at?
PostPosted: 01:16 - 12 Jun 2004    Post subject: Reply with quote
I would expect it to reach those kind of revs in the lower gears if the power valve blanking plate was fitted but I would expect it to reach 8000rpm in top, maybe a touch more, which would be a shade over an indicated 80mph.
The cdi restriction only affects 5000~6000rpm.
Only reason I mentioned oil on the disk is that a small patch of thise could cause the braking to be uneven, but I think this is highly unlikely.
Double and triple check the wheel bearings.
ts50x0
PostPosted: 14:07 - 12 Jun 2004    Post subject: Reply with quote
i think ther may be a cone in the exhaust of the rs125??????? not sure though but ther definatly is on the rs50....
PostPosted: 15:18 - 12 Jun 2004    Post subject: Reply with quote
Only the latest RS125s have blocked up exhausts, except for some imports with catalytic converters.
PostPosted: 16:14 - 12 Jun 2004    Post subject: Reply with quote
I have no idea. I phoned the dealership this morning, they've told me to bring the bike back as its obviously not right. They said that it should be full power and there could be a problem somewhere else. Either way, i'd rather let them sort it while its still under warranty.
Disco
PostPosted: 09:24 - 08 Jul 2004    Post subject: Bike Won't do over 70mph Reply with quote
Hi NS-Keith,
I noticed this post and I just wanted to find out if you managed to sort your problem and what it was?
The only reason I ask is that mine is the same year & model i think, from previous discussion, and mine struggles to go over 70mph.
It gets up to 60mph really fast but then as soon as you whack it into the last gear the revs drop and it just take an year to get up to 7/8k revs and the maximum speed I've had was 70mph.
The bloke I brought it off said the previous owner adjusted the gears slightly, would this make any difference in the performance and the top speed possible?
Any help would be greatful.
Thanks
Danny
Now you see me, Now you don't!
The last post was made 22 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 57.92 Kb
