How long does a plugged tyre last
c-m
PostPosted: 17:21 - 17 Aug 2009    Post subject: How long does a plugged tyre last Reply with quote
I bought a set of michelin pilot sports two weeks ago. This weekend i was riding up throught some twisty country lanes with pillion when i felt the bike go all wobbly.
Turns out i had a puncture. The AA guy said it was a nice clean hole and plugged the tyre for me.
After that my fuel pump died, but thats another story.
Anyway he said that shouldn't really go over 70mph (well officially 40mph) or the plug would overhead. He also said the tyre should be replaced within 200miles.
I've only just bought the tyre and can't afford a new one at the moment. Is the plug likely to be ok?
BadDog
PostPosted: 17:57 - 17 Aug 2009    Post subject: Reply with quote
You really should get a proper plug put in at a workshop, the ones the AA and RAC use are only temporary.
VFR400 NC30 > Kawasaki ZX6R > YAMAHA YZF-R1 > Moto Morini Corsaro Veloce
Blackwolf
Burgerfist
PostPosted: 18:07 - 17 Aug 2009    Post subject: Reply with quote
i bought my tires new and 5 miles later yes 5! ( i waqs not impressed) i got a flat tire. i took it to a garage to fix it still in there no leaks and i need a new tire at ablout 4/5 maby even just 6ks of riding Thumbs Up
CaNsA
PostPosted: 18:19 - 17 Aug 2009    Post subject: Reply with quote
+1 get to a garage and get a "mushroom" instead of that plug.
The mushroom will have pressure on it from the inside holding it fast. The plug u have will be held in with glue of sorts.
I know what i would rather have.
c-m
PostPosted: 18:26 - 17 Aug 2009    Post subject: Reply with quote
Thanks, didn't know they don't use the same ones as a workshop.
I should be able to get this repaired then?
BadDog
PostPosted: 18:34 - 17 Aug 2009    Post subject: Reply with quote
Yep, from between £20-£35. Should last for the life of the tyre then.
That_Hornet
PostPosted: 20:48 - 17 Aug 2009    Post subject: Reply with quote
Yea I got my tyre done 2 weeks back. He said it would last then length of the tyre or he'll replace it for free.
PostPosted: 22:15 - 17 Aug 2009    Post subject: Reply with quote
I've used those figure of eight style push through plugs several times now. They have all still been in when I changed the tyre and looked as solid as the day they were fitted when inspected from the inside.
Maximum I did was 4,000 miles on a plugged tyre and max speed of 157mph.
Friends have had similar experiences. One of whom rode his tyre right down to canvas, the only remaining bit of rubber was the plug.
I'm totally confident in them now and consider it to be a permanant fix.
Not so sure about the plugs that are made of a strip of rubber though, the figure of eight ones mushroom out on the inside once fitted.
binge
Emo Kiddy
PostPosted: 22:20 - 17 Aug 2009    Post subject: Reply with quote
Back in the day, Tyre shops used the same as what the RAC use now, as their puncture patches.
Didnt even remove the tyre to fix the puncture.
But over time, They have been deemed as a Temporary fix and now workshops have to remove the tyre, drill the hole to 6mm, Buff up the area. Clean it down, Glue it. And then pull a mushroom patch through the hole, and roller it flat on the inside. Cutting off the excess rubber flush with the tyre on the outside.
But of a long winded job, But its probably more of a permanent fix as apposed to what the AA / RAC have done...
Punctures are £30 at Watling tyres. If you are local to Medway, Come see me at work. It'll cost you a few beers. Thumbs Up
Ichy
PostPosted: 23:10 - 17 Aug 2009    Post subject: Reply with quote
I had one done last week and it cost £15, the bloke even asked if that was ok.
The last post was made 17 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 65.13 Kb
