Does anyone know what these are?
RudiRulez
PostPosted: 15:46 - 19 Aug 2009    Post subject: Reply with quote
They are definatly autochoke wires, i unlcipped mine one time but my choke still worked it just took a little while longer to work, basicly even without the wires supplying power to the heating element the wax inside the auto choke still heats up and expands causing the choke to turn off because its getting heat from the engine, if you look there is a little window which channels the heat from the engine towards the chokes body to warm it up.
ALSO you have an open air filter which requires more fuel so even if the choke hasnt turned off fully the extra fuel isnt richening the mixture too much.
baldy
PostPosted: 23:45 - 19 Aug 2009    Post subject: Reply with quote
They are auto choke wires. The choke will not work without them, and will be stuck on permanently.
The carb doesn't heat up, as the air induction keeps it cold.
Did you upjet for that filter?
One day i will rule the world, just not today.
The last post was made 17 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 44.53 Kb
