Paraffin on tyres/driveway
Pickledswede
PostPosted: 14:46 - 20 Aug 2009    Post subject: Paraffin on tyres/driveway Reply with quote
Ok so I've been riding my bike a couple of weeks now and just got round to getting some paraffin to clean the chain as the previous owner left it looking like it had been marinated in fermented shit. Basically paraffin has dripped all over my tyre and is running all down my driveway. Are either of these a problem and if so what can I do about it? Also if I have spare paraffin left when I'm done cleaning everything how should I dispose of it?
Preferably before my mum gets home Wink
Thanks guys!
leeclissett
PostPosted: 14:58 - 20 Aug 2009    Post subject: Reply with quote
Oh dear, my basic understanding is that paraffin both causes the tyre to break up and also to swell.
Nothing worse than ruining mums drive though. When I first started driving we were running late for a gig and I managed to spill oil on my mums loose stone driveway. Backed up the car and shovelled away the oily gravel. As I went to pull off the drive I managed to run over the whole container of oil (which I forgot to move!) and ruined atleast 50% of the drive.
Must have spent nearly 2 hours shovelling gravel and though i missed sound check I made it in time for the gig Twisted Evil
PostPosted: 15:22 - 20 Aug 2009    Post subject: Re: Paraffin on tyres/driveway Reply with quote
https://www.stedotcom.com/stuff/firey.jpg
Paraffin is easy to dispose of. Wink
PostPosted: 16:17 - 20 Aug 2009    Post subject: Reply with quote
If there is a big spill, soak it up in cat litter and sweep up the cat litter.
For the remainder and your tyre, hot soapy water.
If you leave the left over paraffin in a container, all the crap will sink to the bottom, you can pour the clean stuff off the top and use it again. I usually put the small amount of paraffin soaked crap you're left with in the bin.
Walloper
PostPosted: 17:17 - 20 Aug 2009    Post subject: Reply with quote
As Stinkers says, do not waste time with sand or shit. It absorbs hee haw.
Neat Washing powder stiff bristle brush and loads of water to emulsfy and dilute the paraffin.
Paraffin will soften the top layer of tarmac so you may be left with some kind of stain/mark.
Pressure washers are good for this jobbie too.
Old paraffin?
BBQ starter. By the time the coals are ready the fumes have been burnt off so no damage done to snarlers, steaks or burgers. Smile
johnsmith222
PostPosted: 17:39 - 20 Aug 2009    Post subject: Re: Paraffin on tyres/driveway Reply with quote
Aye, if you want gum disease and chemical pneumonia.
Try some fire poi or nunchucks instead.
Not that I haven't done fire breathing before. Wink
Pickledswede
PostPosted: 18:21 - 20 Aug 2009    Post subject: Reply with quote
So I should get it off my tyres ASAP?
My mum isn't too bothered about the drive but it does look as if it's been sort of stained. Considering I'm going to be cleaning my chain pretty often is it best to just leave it there? It isn't a big spill it's just a general dampness, next time should I just try to wash it away as much as possible?
Thanks for the help Smile
PostPosted: 18:51 - 20 Aug 2009    Post subject: Re: Paraffin on tyres/driveway Reply with quote
Main risk is if you swallow any then you'll have the shits. Paraffin being cancerous isn't much of a worry when smoking before and after playing with fire. Razz
Fire eating is 'interesting' and is the only time that I've burnt myself when playing with fire.
Back on topic... I'd say yes get it off your tyres. When cleaning the chain, put something in the way to stop paraffin getting on the tyre. IMHO you don't need to cleaning the chain very often.
PostPosted: 20:28 - 20 Aug 2009    Post subject: Re: Paraffin on tyres/driveway Reply with quote
The main risk is if you swallow it, it's also coating the back of your throat and being an oil, you can't feel it's there. This can easily lead to you inhaling some, which again, you can't feel until the lipid pneumonia sets in.
That's why you should always spit out, not swallow any saliva for a good 15 minutes after you've been fire eating/breathing. The fibres in the torch heads aren't very good for you either.
PostPosted: 20:58 - 20 Aug 2009    Post subject: Reply with quote
Drinking full fat milk first helps as well cos that leaves a 'coating' inside your mouth. After fire breathing, rinsing your mouth several times with water/beer helps get the stuff out, swallowing saliva or drinking anything is a bad idea until the taste has gone away anyway.
The way I see it, as a trick done occasionally it's unlikely to do much damage. Where-as the people that work with display teams who're frequently doing lots of fire breathing will more than likely end up with health problems.
squishio
PostPosted: 21:21 - 20 Aug 2009    Post subject: Reply with quote
my mate who washes his bike every other week and uses paraffin liberally on the underneath and commonly greasy bits of the bike (including the wheels)
No noticeable effects to the tires.
however last weekend we found his bike (tdm900) leaning severly (almost on it's side) then realised the side stand had gone through his tarmac driveway and sunk a few inches.
It isn't a great quality driveway but the tarmac is pretty solid and thick but it would seem where he washes his bike in the same spot the drive has gotten really soft clearly demonstrating what paraffin can do.
Cheers!
Rich
Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
Past - SY125, GT250, GT650, CX400, CBF600, Bandit 600, SL1000, GT250
Pickledswede
PostPosted: 00:31 - 21 Aug 2009    Post subject: Reply with quote
Bloody hell Shocked brb, I'm going out with a broom and some fairy liquid! Don't tell my mum!
No, not like that Wink
PostPosted: 00:39 - 21 Aug 2009    Post subject: Reply with quote
More likely it was the sun and the tarmac got too hot.
squishio
PostPosted: 08:20 - 21 Aug 2009    Post subject: Reply with quote
thats what I thought at first but then realised the area is completely shaded my the house and garage.
squishio
thats what I thought at first but then realised the area is completely shaded by the house and garage.
Walloper
PostPosted: 14:15 - 25 Aug 2009    Post subject: Reply with quote
Tarmacudus Wurimus: Annoying parasite which feeds on Tarmacadam.
Main cause of potholes and twitch-iness inducing over-banding irregularities.
The last post was made 17 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 93.04 Kb
