| andwat16 |
 andwat16 Nitrous Nuisance
| baldy |
 baldy World Chat Champion
| andwat16 |
| andwat16 |
| andwat16 |
| baldy |
| andwat16 |
| andwat16 |
| Kickstart |
 Kickstart The Oracle
| andwat16 |
| andwat16 |
 Posted: 20:35 - 22 Aug 2009 Post subject: |
finally back after checking the o ring seal on the radiator, and its in perfect condition
ive tried tightening the two bolts
but evey time i go out for a ride, i look down, and a little bit of oil has dripped onto the oil cooler pipe
i dont know why it might be leaking still?
i also learnt the hardway by not draining oil out of bike before i undid the bolts needed new oil anyways come to think of it, i did put a little bit too much oil in last time (right on the full mark) could that be why?it was overfilling and found a little tiny place to seep out of?
any ideas people
cheers |
| Jeansy001 |
 Jeansy001 Nova Slayer
| andwat16 |
 Posted: 20:47 - 22 Aug 2009 Post subject: |
it was spotless on the insde and on the joints, nice and smooth, i was hoping it was the o ring, but no such luck
if you look at the pic above you can see that the silver (slightly batterd paintwork) pipe, thats were it runs down, but i have noticed that some oil appears above the joint, and a little on the very bottom of the radiator, just above the joint
was worried that the radiator had a a hole in it, but nothing
bit confused
il post pic back up and highlight were i mean:) |
| andwat16 |
| Jeansy001 |
| andwat16 |
| Jeansy001 |
| andwat16 |
 Posted: 21:53 - 22 Aug 2009 Post subject: |
hard to see withit being in dark
just thought to myself, when i was messing about putting it back together, i was moving it backwards n forwards, i may have just moved the oring just out of place, so that might be why it has just started pouring out?
i will get up nice and early in morning and take it out again to see if it has
looks like at this rate il be selling, and looking to get the bandit gt1250  |
| Jeansy001 |
| andwat16 |
| Kickstart |
| andwat16 |
 Posted: 11:19 - 23 Aug 2009 Post subject: |
ahhhh, well, i took it apart again this morning, the seal was fine, but i did noticed on the underside of the radiator were the seal would meet it, that the metal has bobbled alittle, this may have been the cause from the very beginning, with tiny amounts leaking out every so often, but now the oil is flowing out from the top of the bolt
basically, the thread had gone on the radiator, i noticed that the bolt wasnt getting any tighter, i used a bigger and longer bolt, but this still could nnot get it tight enough for it to close the gap
looks like a new radiator for me, unless there is anyother way for it to be fixed?
i will be taking it down to shorrocks in preston in the morning
soooo.....anyone got a couple thousand pounds they have and dont need?im anfter the brand new 1250gt bandit lol |
| Kickstart |
| andwat16 |
| Kickstart |
The last post was made 17 years, 47 days ago. Instead of replying here, would creating a new thread be more useful? |
