I have found the problem with my lights!!
R1stu
Shrek!
PostPosted: 15:32 - 13 Jun 2004    Post subject: I have found the problem with my lights!! Reply with quote
Well me & dandit have stripped the R6 down to the bare minimum to see if we can trace a fault in the wiring, and I think i've may have found it.
What you think?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
carvell
Scuttler
PostPosted: 15:32 - 13 Jun 2004    Post subject: Reply with quote
That be a relay then.
If you know a bit about electronics or how a relay works you could test it out to make sure that it isn't working.
Yamaha TDM 850
KevTM
PostPosted: 15:40 - 13 Jun 2004    Post subject: Reply with quote
if it's cracked like that i would say that it's goosed. I don't know what happened to it, wether it burnt out? or whether it's taken a good knock? either way it's burnt out or could be stuck.
You could test it to see. I think you may be able to get a diagram from Farnell or RS to show how it works. Sorry i can't be of any more help.
PostPosted: 15:51 - 13 Jun 2004    Post subject: Reply with quote
One screwed relay. Thought you had checked those.
R1stu
Shrek!
PostPosted: 16:49 - 13 Jun 2004    Post subject: Reply with quote
There was a small crack in the relay! It must have happened in my front end crash.
And the water has slowly been leaking into the unit. The other wiring loom is from another year so the relays in that were wrong!
So it will be a trip to mr Yamaha then on tuesday.
The last post was made 22 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 44.84 Kb
