| tonyts50 |
 tonyts50 Trackday Trickster
 Posted: 23:29 - 23 Aug 2009 Post subject: how did this happen ? |
ok took my head of the other day after blowing up my suzuki ts50
the piston has hit the spark plug and put a hole in the piston what could of caused this to happen ???
\/ picture \/
https://i391.photobucket.com/albums/oo360/tonymini145/Photo-0066.jpg ____________________ tony ts50 gone from off road to on road to back off road cat c write off
why am i such a prick !!!! im such a fucking soppy bollocks |
| Kickstart |
 Kickstart The Oracle
| tonyts50 |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 23:53 - 23 Aug 2009 Post subject: |
pretty much as kickstart has said.
why do you think you have no back pressure??
a 2 stroke will barely run if it has no back pressure, thats half the principal of a 2 stroke,
are you running premix?? are you running the premix too rich (making it run lean) have you rejetted to suit the bigger bore??
so many variables..... ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| tonyts50 |
| mr rip |
 mr rip Scooby Slapper
| tonyts50 |
| tonyts50 |
| hmmmnz |
| tonyts50 |
| tonyts50 |
| Kickstart |
 Posted: 09:37 - 24 Aug 2009 Post subject: |
What compression is it running with the big bore kit?
24mm sounds like a massive carb for a 50 bored out to 80cc. The main jet should be irrelevant for starting, so switching to a smaller one shouldn't make any difference to how difficult it is to start. Main jet is only relevant at large throttle openings.
As a stock TS50 has either a 12, 15 or 16mm carb, how are you choosing a "stock" main jet to use?
| mr rip |
| tonyts50 |
| Kickstart |
 Posted: 14:12 - 24 Aug 2009 Post subject: |
If it revs straight to 11k it suggests either the throttle was open or there is an air leak after the carb (doesn't take much throttle to give those revs when the engine isn't under load).
What he is suggesting is the correct way to set the oil pump when using the stock carb.
However you are using a far larger carb than standard ( and I would doubt it needs anything that large - 24mm is the stock size for an MBX125, probably capable of almost twice the power of your engine). Even compared to the largest stock size used (16mm), the 24mm carb is 125% larger in area. A massive amount.
Main cause of the damage you have suffered is either too low fuel octane rating, too high compression or too advanced ignition timing. Running lean would make any of these more likely to cause a problem. I take it the timing is standard, but after playing with a big bore kit what compression ratio have you landed up with?
What main jet are you using? What do you mean by a "standard" main jet, given that the carb is nothing like standard for the engine?
| tonyts50 |
| Blau Zedong |
 Blau Zedong Banned
 Posted: 14:41 - 24 Aug 2009 Post subject: |
"Piston hit the spark plug"
Oh Tony you lol me so much!
If someone was ever ill suited to riding around on a hugely overtuned 2T, it would be you. You've chucked bits together with no forethought on setup or even if they will work. ____________________ 18:54:48 Rob Fzs: jews don't give away stuff for free
18:54:59 Rob Fzs: unless its their clothes/ hair/ golden teeth |
| tonyts50 |
| Kickstart |
 Posted: 14:56 - 24 Aug 2009 Post subject: |
Right, trying to go back a few stages.
The fuel / air mix in the cylinder is ignited and burns. As it burns it pushes down on the piston. What you want is a steady burn, not a sudden violent explosion. If the piston is at the very top of the bore then it cannot push the piston down at all (but the momentum of the crank means that it is only like that for a short time).
The fuel / air mix can also ignite just from pressure. Of course as the fuel / air mix burns and expands it increases the pressure within the cylinder anyway, so pockets of unburnt fuel / air mix can rise in pressure enough to just explode. This is known as detonation. At best this will generate a hell of a lot of extra heat (melting holes in pistons and melting spark plugs), but can have a similar effect to hitting the top of the piston with a hammer.
The higher the compression ratio (which is the ratio of the combustion chamber to the total volume of the cylinder and combustion chamber) then the higher the pressure in the head, and so more likely that the pressure will be high enough for the fuel / air mix to ignite on its own. However the higher the compression the more power you get, so it is a balancing act.
Petrol has an octane rating, which is its resistance to detonation. It is measured as the fuels equivalence in resisting detonation to a mix of 2 control fuels, iso-octane and n-heptane. 95 octane fuel has the detonation resistance of a fuel made of 95% iso-octane and 5% n-heptane. If you use a fuel of too low an octane rating then it will be more likely that you will get detonation. There are 2 real ways that a higher octane fuel can resist detonation, either by burning more slowly (so the pressure builds more slowly, but which will cost power) or by being less prone to just exploding due to pressure.
Normally the engine generates a spark before the piston reaches the top. This is so that there is enough time for the flame to spread and start to generate a large downward force on the piston for when the con rod is at a decent angle to the crank to transfer that pressure and turn the crank. If you ignite the fuel /air mix too early then the piston will not have moved down enough by the time the pressure rises enough to cause detonation. If you ignite the fuel / air mis too late then you miss the most effective time for the pressure to push the piston down and turn the crank.
So from that I hope you can see that if you raise the compression (which you quite likely have depending on what the big bore kit ws designd for), then you are more likely to get detonation. You can counter this by using higher octane fuel (which will likely produce slightly less power due to burning more slowly) or retarding the ignition timing (again will lose you power, as the most useful part of the fuel burning will happen later than is best).
The 3 things are a balancing act, and just playing with one and hoping for the best can easily result in damage (such as the hole burnt in your piston).
Running lean will make the engine run hotter anyway, and a lean mix is far less resistant to detonation.
| Kickstart |
 Posted: 15:03 - 24 Aug 2009 Post subject: |
To add to the above, there is also the problem of preigition. You get this when part of the combustion chamber gets hot enough to act to ignite the fuel / air mix. Such as a built up of carbon that starts to glow. This can cause the engine to carry on running even when the ignition is switched off, but also there is the possibility that it will ignite the fuel / air mix before the ignition system would, so giving much the same destructive effect as advancing the ignition timing.
| tonyts50 |
| mr rip |
| Pete. |
 Pete. Super Spammer
 Posted: 05:58 - 25 Aug 2009 Post subject: |
IMO you've holed the piston through too-lean a mixture. Also remember if you've bored the 50cc barrel for a 80cc piston your barrel hasn't the fin area to cope with the extra heat developed, so any full-power blasts should not be held for continuous miles - you have to rest the engine to allow the heat to dissipate.
Your lube system is probably just fine, or you would have seized it not holed the piston. Rebuild the engine and sort the mixture, IMO. ____________________ a.k.a 'Geri'
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 09:07 - 25 Aug 2009 Post subject: |
Bookmark this thread, come back and read it in 5 years time. Then cringe.  ____________________ My Flickr |
| Kickstart |
The last post was made 17 years, 33 days ago. Instead of replying here, would creating a new thread be more useful? |
