electronic speedometers?
mr rip
PostPosted: 00:50 - 26 Aug 2009    Post subject: electronic speedometers? Reply with quote
I'm just finishing off a project bike & it's all going well apart from the fact that neither of the wheels has a speedo drive as the drive came off the front sprocket & seeing as I've put a different engine in it I now have no speedo drive at all
I've been doing some searching & managed to find Trailtech & Acewell speedo's but all their models seem to run on 12v & my bike runs on 6v so no joy there
I've sent emails but had no replies as of yet, so does anyone know of any company selling ones that will run off 6v electrics?
any leads or links would be appreciated
thanks
never criticise a man until you've walked a mile in his shoes, then when the muck hits the fan you'll be a mile away & you'll have his shoes
hmmmnz
PostPosted: 10:24 - 26 Aug 2009    Post subject: Reply with quote
the trail tech ones you can get to run off an internal battery,
failing that the sigma push bike speedos do the job and go to 199mph
the humans are dead
I kick arse for the lord
mr rip
PostPosted: 13:47 - 26 Aug 2009    Post subject: Reply with quote
thank's hmmmnz,
the trailtech battery only runs the memory, from what I can see on their web site, but I'm still waiting to hear back from them. Also, all their kits are model specific making it hard to figure out what bits I actually need for this contraption of mine
the acewell ace-1500 says it will run off an internal battery, but, yet again, no one is getting back to me to say what other parts I need
I've got a cycle computer on there at the moment (2 actually) but the ignition interferes with the signal, so when you rev it up the thing says you're moving even when you're not, they're not legal on a motorcycle anyway because the back-light only stays on for a few seconds at a time
thanks anyway
truslack
PostPosted: 14:04 - 26 Aug 2009    Post subject: Reply with quote
thanks anyway
Run a wire from the sidelight feed to an LED, position the LED so it points down at the speedo.
Depending on the current the electronic speedos need, you could step up the voltage with something like this: https://www.rangevideo.com/index.php?main_page=product_info&products_id=162 But i have no experience of doing that on a bike.
Mark
mr rip
PostPosted: 14:16 - 26 Aug 2009    Post subject: Reply with quote
thanks truslack,
I had thought about putting a little pilot bulb above it to light it up but the interferance from the ignition was still making the thing unusable anyways, so I hadn't got round to it
but the 6v to 12v step up power converter is a realy good idea, I think some early cars ran on 6v so there might be some automotive equivalent out there
I guess I'm off to do some surfing, cheers
truslack
PostPosted: 14:22 - 26 Aug 2009    Post subject: Reply with quote
What current do the electronic speeds draw, any idea?
mr rip
PostPosted: 14:39 - 26 Aug 2009    Post subject: Reply with quote
not sure what current they draw & the info paiges are all a bit vauge, kind of along the lines of "look, its a speedo, add to basket" & not a lot else
as for the power converter, I've just found this one on citron classics website, It says it'll give enough power to run a sat nav or a lighter socket to charge a mobile phone
https://www.citroenclassics.co.uk/custom/Navipower.jpg
looks pretty small & neat, ideal for a bike, but not cheap at £52
I'll keep looking
truslack
PostPosted: 14:47 - 26 Aug 2009    Post subject: Reply with quote
Taken from Trailtech's website:
Power wire for Vapor and Vector computers. White connector snaps into mating connector on computer. Red and black leads are wired into vehicle electrical system (polarity independent.) Computers operate in the range of 6.0-400 VAC/VDC, but will not draw enough power to drain a vehicle battery.
So you should be able to run it without a transformer (if I read that correctly)
truslack
PostPosted: 14:55 - 26 Aug 2009    Post subject: Reply with quote
You should be able to make your own kit up from the spare parts page for a trailtech:
https://www.rpamx.co.uk/acatalog/Trail_Tech_Speedo_Spare_Parts.html
1 Vapor head unit £53
1 Air Cooled Temperature Sensor Vector or Vapor £23.01
1 Motorcycle Speed Sensor Cable Vector or Vapor Computer (I Presume this has the reed switch built in) £18
2 Vapor Power / Tacho Cable £10.02
1 Handlebar Mount for Vapor / Vector £10.02
1 Sensor Magnets (All Trailtech Computers) £4
Obviously you only need ALL this if you want temp sensing, tacho etc.
Hope this helps
PostPosted: 15:07 - 26 Aug 2009    Post subject: Reply with quote
You can get lights for them, or make up an LED or similar to point down at it, if it bothers you.
Is yours a wireless one? I've never had a problem with interference from a wired one. My £6.99 tescos one would start to show incorrect speeds (1/2, 1/3 of real speed) above 50mph or so, however the more expensive one on my zx9 is fine and GPS-tested accurate to well into triple figures. It's been on there for five years or so and in the last year has done over 4000 miles. Just had to replace the battery and it kept all the readings from before too. Think it's a "Cat's eye" one maybe.
serlant
PostPosted: 15:10 - 26 Aug 2009    Post subject: Reply with quote
Just connect up a square 9v battery, i've got a Trailtech Vapor, and in the manual it says, 9.0-400v AC/DC polarity independent, just connect up a 9v battery and keep a couple of spares in the seat.
map
Mr Calendar
PostPosted: 15:18 - 26 Aug 2009    Post subject: Reply with quote
G wrote:
...the more expensive one on my zx9 is fine and GPS-tested accurate to well into triple figures...Think it's a "Cat's eye" one maybe.
So that'll be these people then, cateye.com.
Very Happy
mr rip
PostPosted: 15:31 - 26 Aug 2009    Post subject: Reply with quote
thank's for the tips guys
truslack where did you find that info on the trail tech website cause I couldn't find it , I must be blind,
I better go back & have a proper look eh?
temeluchus
PostPosted: 15:34 - 26 Aug 2009    Post subject: Reply with quote
thanks anyway
Ive had a few bikes pass MOTs with them on. There is no part of the MOT test that covers backlights for instruments.
truslack
PostPosted: 15:38 - 26 Aug 2009    Post subject: Reply with quote
You don't need a speedo for MOT - it doesn't cover all the things required for a bike to be road legal.
Mark
truslack
PostPosted: 15:39 - 26 Aug 2009    Post subject: Reply with quote
It says it in the description of the power cable on the spare parts page.
It will probably state it somewhere else aswell
Mark
[edit]
Weird. on the vapour spec page it says EXTERNAL POWER INPUT
9.0-400 VAC/VDC
What I overlooked until now however, is the fact that the 6v mag will surely make an AC current higher than 6v (quite a lot higher), which is then brought down to 6vdc at the reg - you could take a feed from before the reg to power the speedo.
[edit2]
Further down the spec sheet, it says
"• Vapor will operate in the range of 6.0 - 400 VAC/VDC."
mr rip
PostPosted: 15:49 - 26 Aug 2009    Post subject: Reply with quote
I just saw it in the power lead discription, DOH,
it would have been easier if they said that in the main speedo description paige though
I still have the problem of all their senders & leads all being model specific, I could take a gamble & order one at random but you never know what your going to end up with
I am a few steps closer to knowing what I need though so I'll keep brousing
thanks
truslack
PostPosted: 15:50 - 26 Aug 2009    Post subject: Reply with quote
thanks
Read the post above, the spec sheet for the vapor speedo contradicts itself in various places, I rang up trailtech and they say it only works on 12v.
Might be an idea to go down the direct from the mag route perhaps.
Spec sheet is here:
https://www.trailtechproducts.co.uk/acatalog/vapor_instructions.pdf
mr rip
PostPosted: 15:55 - 26 Aug 2009    Post subject: Reply with quote
it's a 6v three phase DC generator & at top wack it only just get's up to 8v, & not realy understanding how it works I wouldn't know where to take a feed off it
serlant
PostPosted: 16:59 - 26 Aug 2009    Post subject: Reply with quote
I just went and checked with a 9v battery and a 6v pack i made up quickly and neither worked.
mr rip
PostPosted: 17:19 - 26 Aug 2009    Post subject: Reply with quote
thanks for that, I just saw a link to the instruction manual for the trailtech vector & it says it'll run from 9v, so I figured I'd be able to run it off a pp3 duracell, but now we know better eh?
serlant
PostPosted: 17:22 - 26 Aug 2009    Post subject: Reply with quote
yeah i mentioned that above, which is why i thought i'd give it a try.
mr rip
PostPosted: 01:03 - 01 Sep 2009    Post subject: Reply with quote
I obviously got bored reading all the diferent modles on the list on the trailtech website & gave up too soon cause right at the bottom of the list is a generic model for standard forks,
I'm hoping it's the one you need if you don't have a speedo drive cause I've just ordered it
at least it'll look like I've got a speedo on there untill I can get the power sorted out
https://www.trailtechproducts.co.uk/acatalog/75-200.jpg
I'll get out there tomorrow & check the genny output if it's no good it'll have to be a power converter
PostPosted: 05:45 - 01 Sep 2009    Post subject: Reply with quote
Just a point, my S4's speedo would flicker reset and generally crap out if the battery was low I can't imagine a 6v powered bike could keep a speedo running. My RXS couldn't even run my indicator and the brake light Laughing
Ichy
PostPosted: 08:40 - 01 Sep 2009    Post subject: Reply with quote
How about emailing Trailtech, [email protected] ? I'm sure with the amount the sell they must have dealt with 6v before.
Maybe you can get someone to knock this up?
https://www.electronics-lab.com/projects/power/030/
https://www.aaroncake.net/Circuits/6-12conv.asp
https://www.austin7.org/6v_to_12v_converter.htm
No idea what the current draw is but there are these sort of things for low power applications.
https://www.dimensionengineering.com/AnyVoltMicro.htm
The last post was made 16 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.29 - MySQL Queries: 13 - Page Size: 130.34 Kb
