Hornet Rad Cover
That_Hornet
PostPosted: 17:59 - 25 Aug 2009    Post subject: Hornet Rad Cover Reply with quote
My radiator cover vibrates horibly when im on the bike.
Not loose bolts its in the middle at the bottom that had no support and vibrates, making loads of Thumbs Down noises.
Any help?
hellobaby
PostPosted: 18:33 - 25 Aug 2009    Post subject: Reply with quote
You would probably be better off asking on the Hornets Nest, anyway are you sure its not just loose bolts, Torque everything up around the area of the noise and see if it makes a difference.
CBT - 10/05/08, Theory 7/05/08
JakeyR
PostPosted: 01:32 - 26 Aug 2009    Post subject: Reply with quote
or just take it off cos radiator covers scream "IM GAY"
alun111
PostPosted: 01:46 - 26 Aug 2009    Post subject: Reply with quote
Wasn't it you who damaged their rad when a stone hit it? Laughing
To the OP:
Are you sure it's the rad? If you're positive then check the bolts out... some of the bolt holes in the rad have a rubber grommet on them... make sure they are all there.
JakeyR
PostPosted: 01:57 - 26 Aug 2009    Post subject: Reply with quote
yeah okay they serve a purpose because i got a stone through my rad, they look okay unless its a gash design, if its just a bog stock design without writing all over it i like um! lol.
carlperkins00...
PostPosted: 08:32 - 26 Aug 2009    Post subject: Reply with quote
i had that trouble too...
but the holes in my radiator cover were abit big for the bolt.
so i bought 4 little rubber gromits and drilled the holes in the radiator bigger, put the gromits in, loctite on the bolt and put it together. worked fine.
it must be the bolts, unless the rad cover is really thin and flimsy??
That_Hornet
PostPosted: 08:38 - 26 Aug 2009    Post subject: Reply with quote
It's beowolf cover. It's 2mm thick. I'll take it off tonight and get some grommets. Thanks
The last post was made 17 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 51.64 Kb
