| RaVeR_mt50 |
 RaVeR_mt50 Borekit Bruiser
 Posted: 22:07 - 13 Jun 2004 Post subject: mt50 faster? |
Hi im new on this site please don't flame me cause of my bike im only 16 just passed cbt my mt has a dep pipe which are apprently the best but it only still tops out 40-45 do these bikes have any other restrictions I should know about. all the scooters leave me for dust
thanks |
| MarJay |
 MarJay But it's British!
 Posted: 22:38 - 13 Jun 2004 Post subject: |
Maybe a little punctuation?
Unfortunately I imagine that with an MT50, as with a lot of 50ccs you need to buy a better bike to go faster. if it does 45 then it isn't restricted, and so I doubt that you'll get it to go any faster really.
Sorry I can't be of more help, but 50's are designed to do 30 and little more I'm afraid.
as the old adage goes, you pays yer money, you takes yer choice. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| RaVeR_mt50 |
 Posted: 22:40 - 13 Jun 2004 Post subject: |
oh well I will see how a big bore kit goes maybe will keep up with the hair dryers then  |
| carvell |
 carvell Scuttler
| RaVeR_mt50 |
| RaVeR_mt50 |
| RaVeR_mt50 |
 Posted: 22:17 - 14 Jun 2004 Post subject: |
Hmm this sounds like a good idea to do when im 17 insted of buying a new bike these h100 engines hard to come by?  |
| badlydamaged |
 badlydamaged Spanner Monkey
 Posted: 22:27 - 14 Jun 2004 Post subject: |
Shouldn't think they are hard to come by, H100s were made until 13 years ago so theres still some about. Have a look on part finder to search bike breakers for a complete engine, although id expect youd pay about £100 - £120 for a working one with carbuerttor etc.
https://bike-breakers.info/web_pages/HomeFrame.htm
Good luck! ____________________ My bike: 1988 Kawasaki KH100 Status: Polluting Devon with two stroke smog and noise pollution!
"Its not your engine size that matters!, It's what you do with it that counts"
Add me to MSN if you want! [email protected]. |
| Frost |
 Frost World Chat Champion
 Posted: 23:24 - 14 Jun 2004 Post subject: |
what is the law on changing engines? does the bike then leagally change capacity or is it just couted as a modification?
I have a 125 superdream, these things are hellishly expensive considering what you get. where as the 250 dream is dirt cheap as no one wants them, as they would rather get a bigger bike. so could i buy a 250 dream, drop a 125 in it,. then legally ride it on L plates?
If so i think ive found a nice little earner  |
| R1stu |
 R1stu Shrek!
 Posted: 00:05 - 15 Jun 2004 Post subject: |
I used to have an MT50. My one did about 45-50 at a push.
If you put a BB Kit in it dont expect it to last long. The MT50 was one of the worst 50cc bikes for them, and always blew up very quickly. (Con rod snapping). ____________________ Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished) |
| RaVeR_mt50 |
 Posted: 02:25 - 15 Jun 2004 Post subject: |
hmm I think a bb isnt a good option then anything else I can do to make it go faster?? without making the reliablity fall?  |
| Frost |
| RaVeR_mt50 |
 Posted: 02:53 - 15 Jun 2004 Post subject: |
it hits diffrent speeds diffrent days I avarage out at about 37 good road and day will have 40 and a slight slope will have 45 and after it if the road is stright it will stay there  |
| Frost |
| RaVeR_mt50 |
 Posted: 11:20 - 15 Jun 2004 Post subject: |
ok well thanks it does run well and had good paint not much rust etc will try keep its value the same for when I sell it  |
| RaVeR_mt50 |
 Posted: 19:28 - 15 Jun 2004 Post subject: |
Suspect you will struggle to get those kinds of speeds from it, partly from gearing (similar to the H100 you cannot gear them high enough for a proper top speed). That would probably require 6~8hp, and the MT5 engine is not that good.
Carb wise not sure what is available, but I would doubt the reeds would make any difference to top speed at all (they allow fuel / air into the engine crankcases while the piston is going up, but stop it getting back out through the carb when the piston is going down). However not sure if the MT5 uses fibre reeds or steel reeds but if they are steel then it might be worth upgrading just so when they fail they are less likely to damage the piston / barrel.
| mrchips |
 mrchips World Chat Champion
 Posted: 20:59 - 15 Jun 2004 Post subject: |
My MT50 was dead slow, so I took the frontpipe off and cleaned out the port - it was half clogged. This gave me improved acceleration and a bit of a bigger top end - 40mph. The standard MT50 speed is 35mph, so I think unless you are willing to spend money on a good quality big bore kit and gvie it a good run it it may be good for a few thousand miles. As for derestriction - you will have to get a bigger carburetter - at least 16mm as the one on it is 13mm. There is also a stopper plate over the reed valve, so rather than breaking that off, buy race reeds for it. To be honest I left mine standard because straining an engine of that age will do more harm than good. I'd say get race reeds to improve acceleration but as for top speed get used to it, then you will appreciate your 125 an awful lot more.
EDIT: Some sites you may find benificial are www.myhondamt5.cjb.net and www.50cc.nl |
| ts50x0 |
 ts50x0 Spanner Monkey
 Posted: 11:20 - 16 Jun 2004 Post subject: |
dont wqprry about the scooter boys overtaking you i used to be like that on my ts50. but now ive got my nsr i just lagh at how pathetic their little hair dryers are as i go flying past them with my knee down. good luck if you decide to tune it. you can get bb kits from www.mandp.co.uk ....
ps. good on you for getting a real bike even if it is a bit slower!!!! |
The last post was made 22 years, 112 days ago. Instead of replying here, would creating a new thread be more useful? |
