gps bracket
Peirre oBollox
PostPosted: 08:27 - 25 Aug 2009    Post subject: Reply with quote
if he has the cash try Gadet guy https://www.gadgetguy.net/ but it ain`t cheap (£80+) as its made in the USA, and likely to subject to import taxes into the UK potentially adding around 33% to the price
I have this mount on my triumph for my Zumo 550 and I`m happy with it, and would recomend it, its wired to a starcom
my setup
https://i224.photobucket.com/albums/dd88/PeirreOBollox/Sprint%20ST%20GPS%20power%20connector/th_P4280085.jpg
components
https://i224.photobucket.com/albums/dd88/PeirreOBollox/sprint%20St%201050%20-%20Gadget%20guy%20GPS%20mount/th_Sprintbracket.jpg
https://i224.photobucket.com/albums/dd88/PeirreOBollox/sprint%20St%201050%20-%20Gadget%20guy%20GPS%20mount/th_UniversalBracketKitMkII.jpg
https://i224.photobucket.com/albums/dd88/PeirreOBollox/sprint%20St%201050%20-%20Gadget%20guy%20GPS%20mount/th_Baseplate.jpg
component parts can be bought here https://gpsforless.stores.yahoo.net/motbracforga.html
its a mix & match setup of bracket parts, depending upon the bike its used on. if in doubt email gadgetguy the details (bike/year/zumo) and find out which parts he needs
suggs
PostPosted: 17:47 - 25 Aug 2009    Post subject: Reply with quote
a Ram mount may work for you, try ebay theres normally some on there. or is that what comes with the zumo anyway?
suggs
PostPosted: 21:59 - 25 Aug 2009    Post subject: Reply with quote
this sort of thing, theres also other options for mounting onto the top yoke or other points were theres a nut and bolt..
https://cgi.ebay.co.uk/Garmin-RAM-Mount-Bracket-Holder-Zumo-400-500-550-GPS_W0QQitemZ370189434846QQcmdZViewItemQQptZUK_CE_GPS_Accessories_Software_ET?hash=item5631027fde&_trksid=p3286.c0.m14#ht_3592wt_934
Peirre oBollox
PostPosted: 07:36 - 26 Aug 2009    Post subject: Reply with quote
suggs wrote:
covdude wrote:
thanks
thats the seller i had messaged !
steve
Thats the stock Garmin/Ram mount.
"covdude" AFAIK in your OP you stated the stock mount is unsuitable
covdude wrote:
my brothers got a zumo garmin 550 and cant mount it on his handlebars with the standard mount
however you could also try Telefreizer
https://www.telferizer.com/
suggs
PostPosted: 18:00 - 26 Aug 2009    Post subject: Reply with quote
Peirre o`Bollox wrote:
suggs wrote:
covdude wrote:
thanks
steve
yeah he will make you a mount that fits your bike and then the standard ram mount fits to that, he normally makes them with a 1 inch ball on the end and some fit onto the nut on the top yoke
Peirre oBollox
PostPosted: 21:18 - 26 Aug 2009    Post subject: Reply with quote
85mm ............ you sure?
Peirre oBollox
PostPosted: 04:46 - 27 Aug 2009    Post subject: Reply with quote
covdude wrote:
brothers handlebar is 85mm diameter ?
covdude wrote:
Does that seem to small/big ?
Yes .......... bars usually come in either 7/8"(22mm) or 1"(25mm) - Harleys etc
unless your measuring them somewhere else
suggs
PostPosted: 05:58 - 28 Aug 2009    Post subject: Reply with quote
look at mounting it some were else and not the bars, heres a quick bodge i did recently as i needed to use a satnav.
i mounted it to the nut on the top yoke..
https://i32.photobucket.com/albums/d43/karting4/250720091249-1.jpg
map
Mr Calendar
PostPosted: 09:27 - 28 Aug 2009    Post subject: Reply with quote
covdude wrote:
...85mm via a tape maeasure wrapped around the bars, circumference if thats the word.....
Using the power of the interweb, well this site, 85mm works out at external diameter 27.06mm.
Old school, circumference = 2 x pi x radius.
As radius = diameter / 2 then
circumference = pi x diameter
so
diameter = circumference / pi (3.14159)
If you get an accurate diameter using a vernier calliper (or micrometer > 25mm) you may find it actually works out at 25mm as mentioned above.
https://www.screwfix.com/sfd/i/cat/76/p4620976_l.jpg
click on image for link to screwfix
HTH Thumbs Up
The last post was made 17 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 96.33 Kb
