How long does it take your tyres to heat up ?
Gazz
PostPosted: 19:47 - 27 Aug 2009    Post subject: How long does it take your tyres to heat up ? Reply with quote
After reading the thread "Low Pressure" on here I was wondering how long it takes for your tyres to heat up?
The reason I am asking is because you are supposed to check and alter your tyre pressures when the tyres are cold, however; I stay 2 miles away from a garage which does a free air and water machines.
I have ridden to this garage a few times and checked the tyre pressures, and have always worried if I was getting an inaccurate reading because the tyres will not be as cold as they would have been when I left the house.
Will this short journey make any difference ?
MattEMulsion
PostPosted: 20:18 - 27 Aug 2009    Post subject: Reply with quote
Not a lot I wouldn't have said, in fact I dare bet that the guage at the garage is probably not that accurate anyway.
Yamaha YZF-R6
yen_powell
PostPosted: 20:55 - 27 Aug 2009    Post subject: Reply with quote
What you need is a tyre gauge and a footpump.
XT1200Z and a DR350 in bits
bikedemon99
PostPosted: 20:56 - 27 Aug 2009    Post subject: Reply with quote
you worry too much, are you knee down to the garage or something, my front was too low and gripped great, sorted it and it was slippier umm!!!
Ride safe
KevTM
PostPosted: 21:05 - 27 Aug 2009    Post subject: Reply with quote
Ride to garage, leave bike standing for 5-10 minutes then do the pressure?
PostPosted: 00:04 - 28 Aug 2009    Post subject: Reply with quote
Digital tyre pressure gauge £5
Footpump £10
Garages are crap
Pat
binge
Emo Kiddy
PostPosted: 01:55 - 28 Aug 2009    Post subject: Reply with quote
I run Nitrogen in my tyres. I check the pressures every few weeks but have never had to adjust them since using Nitrogen.
The only difference is, You have to run the pressures a few PSI higher than you would with normal Air. Because Nitrogen doesn't expand like normal air when the tyres heat up.
Ben
MattEMulsion
PostPosted: 09:16 - 28 Aug 2009    Post subject: Reply with quote
Well if it perfromed better with a little less air in it, then let some back out. The manufacturers recommended pressure is only a recommendation, not a must.
Yamaha YZF-R6
bikedemon99
PostPosted: 15:51 - 28 Aug 2009    Post subject: Reply with quote
Yep your right there but the reason it was so noticable was it was wet and my tyre was softer with lower preassure so thefore grippier but when I topped it up it became harder and less grippy in the wet thats why I dont worry too much about my tyres being a little soft in the wet, note " a little" I would like it to come off the rim haha Smile
Ride safe
Finglonga
PostPosted: 12:26 - 29 Aug 2009    Post subject: Re: How long does it take your tyres to heat up ? Reply with quote
Won't make any difference if they are fully up to temp as the gauges on garage pumps are that inaccurate that your still going to be riding around with the wrong pressures.
Get your own pump and gauge, they will pay for themselves in a couple of tyre changes.
Andy Sez....
F.Y.Y.F.F.
plugger147
PostPosted: 12:47 - 29 Aug 2009    Post subject: Reply with quote
Buy an electric fag lighter pump cut the ciggie lighter end off and attach crocodile clips. don't trust the dial gauge's get a decent digital pressure gauge they aren't to expensive and a lot more accurate.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
LeeR
PostPosted: 15:34 - 29 Aug 2009    Post subject: Reply with quote
An old rule of thumb was to put 10% more in warm tyres i.e. 28psi would be 31psi warm etc...
My claim to fame: Austin Vince nicked my pen...
The last post was made 17 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 73.45 Kb
