Notchy steering?
yuri2085
PostPosted: 12:59 - 28 Aug 2009    Post subject: Notchy steering? Reply with quote
When I had some work done on my bike they rode it around a bit after and told me that I had 'notchy' steering acting like I already knew. I personally had no idea what he was talking about and I have tried testing in the best way i could assume by doing that low (ish) speed rocking/wobble of the bike and it all seemed smooth.
How does one check for notchy steering (assuming steering head bearings?) and could this account for a recent high speed (110 or so...private road) wobble I had. I thought it was something to do with my lack of fairing and upright position causing the front wheel to lift sightly (with my incredible wind resistance in textiles); with the wobble increased by the obviously non symetrical wind resistance.
I question this conclusion because people say lifting the weight off the front wheel helps control a high speed wobble :s
Perhaps I have given too much info :p
Thanks in advance.
PostPosted: 13:02 - 28 Aug 2009    Post subject: Reply with quote
put the bike on a centrestand or paddock stand and turn the bars from left to right. You should notice it then. You will probably need to replace the steering head bearings.
daytona55
PostPosted: 13:50 - 28 Aug 2009    Post subject: Reply with quote
Also you could try and block the front wheel straight, (or put it between your knees facing the bike) then try and steer the bars, see if you get any play then.
clancy
PostPosted: 13:56 - 28 Aug 2009    Post subject: Reply with quote
exactly that, failed my MOT due to notchy steering. new headrace bearings..sorted Thumbs Up
yuri2085
PostPosted: 14:38 - 28 Aug 2009    Post subject: Reply with quote
Alright will be doing these checks, thing is i recently had an MOT (2 weeks before the garage said something about it...a different garage) and I watched him checking my steering head and he didn't notice anything off.
Do you guys think my initial diagnosis of the cause of the high speed wobble isnt possible?
clancy
PostPosted: 21:44 - 28 Aug 2009    Post subject: Reply with quote
at high speed the front can feel light and twitchy.
but thats relevant to all bikes, so someone wouldnt point that out. and you say someone pointed it out after having some work done? they wouldnt know about how it feels at high speed, unless they drove your bike?
yuri2085
PostPosted: 23:13 - 28 Aug 2009    Post subject: Reply with quote
Ye they only drove it at less than 10 mph around their little industrial estate. And I sat there for 5 mins today with the front wheel off the ground felt really smooth. (no movement with legs jamming wheel too).
I think he was just imagining it and the wobble was other reasons.
Thanks guys Smile
yen_powell
PostPosted: 23:21 - 28 Aug 2009    Post subject: Reply with quote
Get the front wheel in the air (at a standstill, I don't mean do a wheelie).
Turn the handlebars slowly left and right. If you can feel that the wheel wants to point straight ahead (that's where the notch in the headstock race will be so the bearing balls try to drop into the worn part) rather than flop to one side or the other you have got notchy bearings. It's just wear in the straight ahead position.
XT1200Z and a DR350 in bits
yuri2085
PostPosted: 23:31 - 28 Aug 2009    Post subject: Reply with quote
Hmm thats interesting I asked my mum to have a go and she did say 'it seems to go back to the middle easier than away' but I either thought that's a good thing or she is imagining it.
I will investigate in a more paranoid manner tomorrow Smile
yen_powell
PostPosted: 10:31 - 29 Aug 2009    Post subject: Reply with quote
That sounds like it.
Mine became notched a while ago and it means that when riding at slow speeds where you would normally have the front wheel moving slightly left and right to keep balance, it trys to point straight ahead instead.
When you tap the old races out you can hardly see the indentation, it just looks like a scuff mark. Anyway, the bearings and races have had it, best to replace them and pack the new ones with plenty of grease so they last forever. Manufacturers hardly put any grease in them at all.
PostPosted: 11:31 - 29 Aug 2009    Post subject: Reply with quote
To check for notchiness put the bike on the centrestand and get someone sat on the rear of the seat, so the front wheel is in the air. Now put the steering dead straight and standing next to the tank get hold of the bar grips with just your fingers using a light grip, turn the steering a small amount left and right very gently. If you feel a 'lump' in the steering as it passes middle, that's what the fitter is talking about.
If you can only just feel it then it can't be that bad and actually might have been mot-passable though they should have given you an advisory. If it is more pronounced it will try to hold the steering pointing ahead and you need to change the bearings. If you can't feel any notchiness then the garage might well have been looking to bill you for some un-necessary work.
yuri2085
PostPosted: 14:34 - 29 Aug 2009    Post subject: Reply with quote
Ok there is a small lump/notch in the middle.
Is it really worth fixing as in does it make a difference ? Smile
edit: read that bit about low speeds, I don't have any problems with low speed balance but you reckon it could become an issue soon?
PostPosted: 15:02 - 29 Aug 2009    Post subject: Reply with quote
How bad it is can only be judged by experience. I've seen some where you could swing the bars and they would stop in the middle like a saloon door, and others so loose that they would knock over bumps in the road.
TBH your high-speed weaving is more likely to be tyre related.
yuri2085
PostPosted: 17:09 - 29 Aug 2009    Post subject: Reply with quote
Vincent wrote:
It's not great practice but you might get away with replacing just the top bearing. It's normaly the bottom one that's a pain to renew.
I had a look in the haynes and it does seem rather a lot of effort to replace the bearings ^^. Its basically a case of moves more easily over the center 30% (where they are more worn in i guess?) and a small notch in the center a tiny bit to the left.
I have never noticed it while riding and I think the wobble is related to the incredible unfaired wind resistance of textiles on an upright riding position. (hopefully not tyre as it is only 200 miles old).
I was hoping i could unscrew a bit and go hey some bearings, take them out...clean and regrease (or replace some)and all done. Sad
PostPosted: 17:51 - 29 Aug 2009    Post subject: Reply with quote
Nope, sorry its not that easy but it needs to be done otherwise it will fail an MOT. The key with these things is to try to do them yourself otherwise you won't learn. I've done it a couple of times and it isn't fun but it is satisfying when you've done it.
The last post was made 17 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 101.22 Kb
