probably one for keith ?
tonyts50 This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
mr rip
PostPosted: 23:15 - 28 Aug 2009    Post subject: Reply with quote
what do you mean you can't find an inlet manifold? the mounting flange on the barrel is the inlet manifold,
the carb is ment to slip straight onto those two studs, if it doesn't then you've got the wrong carb
or do you mean the black heatproof spacer?
never criticise a man until you've walked a mile in his shoes, then when the muck hits the fan you'll be a mile away & you'll have his shoes
lukamon
PostPosted: 17:41 - 29 Aug 2009    Post subject: Reply with quote
also, carbs are almost never EVER "knackered", it probably just needs cleaning
killa wrote: Im an ass man myself
PostPosted: 17:54 - 29 Aug 2009    Post subject: Re: probably one for keith ? Reply with quote
tonyts50 wrote:
i have just bought a nw carburettor after i found out my old one as knackerd so i bought a 21mm mikuni carb for my bike only trouble is i cant find the correct intake manifold for it can you help ?
this carb is for my suzuki ts50x
also would a 1991 suzuki dr 125 rear mudguard fit my ts50 ?
Bikes are not like lego. You can't just fit any old carb to any old bike. I suspect if you're using a wildy different carb for your bike, then you'll need to get an inlet manifold made, unless by some wild chance one exists with the correct diameter at both ends.
Clean and refurb the original carb. There is nothing on a carb to be knackered except the jets, slides, float needle, float seat and float. You can get all of those parts seperately It could also be a seal if its leaking, which again are available. Ebay is your friend when it comes to that. If not, try allens performance.
https://www.allensperformance.co.uk/
Jamie S
PostPosted: 19:32 - 29 Aug 2009    Post subject: Reply with quote
A standard ts50 will run absolutely crap with a 21 mm carb, the standard carb is 13mm, the biggest recommended size is 16/17mm, and thats for use with a 70cc "big bore" barrel and an after market exhaust system.
As said above, chances are yours just needs a good clean and overhaul, your pissing in the wind trying to get your TS to run properly with a 21mm carb.
What makes you think you need a new carb ?
mr rip
PostPosted: 19:36 - 29 Aug 2009    Post subject: Reply with quote
the inlet tract on a 2t is a set tuned length to match the port timing of the cylinder & the exhaust expansion chamber to get the optimum amount of fuel into the barrel just as the eco from the exhaust stops it from going any further.
putting any extra manifold on there could completely reck the performance of the machine making it slower than it was when restricted, as the mixture would take longer to get to the bore meaning the eco from the exhaust will be pushing back into the barrel cutting the fuel of too soon. causing you to have too little fuel in the barrel and another piston with a big hole in it due to over weak mixture,
find out what's supposedly knackered on the stock carb & get it sorted properly before you fuck the thing up beyond repair
Jamie S
PostPosted: 09:20 - 30 Aug 2009    Post subject: Reply with quote
The standard main jet is 72.5.
Jamie.
The last post was made 17 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 57.48 Kb
