NSR 125 Cylinder
Suppo
PostPosted: 13:30 - 31 Aug 2009    Post subject: NSR 125 Cylinder Reply with quote
Hey, I have Honda NSR 125 -01 model. my cylinder got broken due piston ring cut off. So I'm in need of new one. If you guys know any good sites for cheap cylinders please give me links Smile. I don't actually care about the size of cylinder.
Thanks!
Alexio
PostPosted: 14:18 - 31 Aug 2009    Post subject: Reply with quote
If the bore is damaged then replacing it is basically like replacing the engine, unless I'm not understanding you? It's pretty easy to find new piston kits but if you need your engine fixed because the cylinder is screwed up then you might need it rebored. If you did this it would no longer be a 125, and so might be illegal for you to ride.
PostPosted: 14:21 - 31 Aug 2009    Post subject: Reply with quote
NSR has a plated barrel and cannot be rebored. Can be welded up and then replated, or can be bored out and have cast iron slieve fitted.
The last post was made 17 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 35.45 Kb
